Classic Hondas All Pre-1988 Hondas.
Honda CRX Si 87 FUEL PROBLEM
Old Apr 17, 2008 | 08:12 PM
gonzalezjk's Avatar
Default Honda CRX Si 87 FUEL PROBLEM
Hi. I have this problem with my Honda CRX Si 87. Everything was good until they painted the car. The car was running and after they finished with the repair, the car cranks but wont start. Changed the fuel filter but after installed it, there is not fuel coming out of the fuel filter. It have fuel in the thank the fuses are good. Do not know if this car have a relay on it. The spark plug cables have spark. Any ideas of what the problem could be? I dont want to buy a fuel pump for $103 if that is not the problem. Thanks for your time and help.
Old Apr 18, 2008 | 04:19 AM
superex87's Avatar
Default Re: Honda CRX Si 87 FUEL PROBLEM (gonzalezjk)
sounds like a dead fuel pump, check to make sure the pump is getting power when the key is turned to the on position, it will come on for 2 seconds then turn off, do you hear the pump prime when you turn the key to the on position?
Old Apr 19, 2008 | 05:45 PM
gonzalezjk's Avatar
Default Re: Honda CRX Si 87 FUEL PROBLEM (superex87)
Problem fixed! Fuel Pump was bad. Thanks for your help!
civicb16eg
Aug 24, 2010 01:38 PM
nsone
May 14, 2009 04:35 AM
oakpwr
Oct 25, 2008 05:54 PM
ferny
Dec 15, 2005 06:12 AM
