Honda CRX Si 87 FUEL PROBLEM
Hi. I have this problem with my Honda CRX Si 87. Everything was good until they painted the car. The car was running and after they finished with the repair, the car cranks but wont start. Changed the fuel filter but after installed it, there is not fuel coming out of the fuel filter. It have fuel in the thank the fuses are good. Do not know if this car have a relay on it. The spark plug cables have spark. Any ideas of what the problem could be? I dont want to buy a fuel pump for $103 if that is not the problem. Thanks for your time and help.
Re: Honda CRX Si 87 FUEL PROBLEM (gonzalezjk)
sounds like a dead fuel pump, check to make sure the pump is getting power when the key is turned to the on position, it will come on for 2 seconds then turn off, do you hear the pump prime when you turn the key to the on position?
oakpwr
10-25-2008 05:54 PM
