WHITE SMOKE!!!!??????
Old Apr 17, 2008 | 08:03 PM
JDMHondaEJ8's Avatar
Default WHITE SMOKE!!!!??????
my car starting spitting white smoke outta the exaust. and when i drive it it sputters alot and wants to shut off if i dont rev it sometimes. what are the possibilities it could be to cause this. anything will help! thanks After a few miles the light started flashing and the engine now runs rough and seems to lack power. The temperature is fine though.
Modified by JDMHondaEJ8 at 12:53 AM 4/18/2008
Old Apr 17, 2008 | 08:06 PM
roycivic92's Avatar
head gasket
Old Apr 17, 2008 | 08:09 PM
Default Re: (roycivic92)
im really new to this all. how bad is that and how much would that cost
Old Apr 17, 2008 | 08:11 PM
roycivic92's Avatar
what motor do you have
Old Apr 17, 2008 | 08:13 PM
Cookie's Avatar
Default Re: WHITE SMOKE!!!!?????? (JDMHondaEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHondaEJ8 &raquo;</TD></TR><TR><TD CLASS="quote"> what are the possibilities it could be to cause this. </TD></TR></TABLE>
Water.
obuhmyuh's Avatar
sorry dude, you're in for some pretty major work.
white smoke= coolant entering cylinder = blown head gasket.
give some history. has the car overheated recently? Thermostat ok? Do you have coolant dripping down your block? How quickly are you losing coolant?
Make sure your radiator cap is functioning, it can lead to blown hg-like symptoms. Ask me how i know
i have a D16y8 and also i smell gas coming from my rail.plus a wire came i undone. could it be that also
Old Apr 17, 2008 | 08:14 PM
obuhmyuh's Avatar
i think the last quote i heard about for a hg was about a grand. and it's always a good idea to replace your water pump and timing belt while you have that **** apart.
Old Apr 17, 2008 | 08:15 PM
obuhmyuh's Avatar
Default Re: (JDMHondaEJ8)
which wire?? but probably unrelated, unless it has something to do with your cooling system (not likely).
Old Apr 17, 2008 | 08:18 PM
EKstacy's Avatar
Sounds like a headgasket to me. Me and my dad replaced mine last week and got my head resurfaced and a valve job done. It totaled up to about $350 for the headwork and a full gasket set. We did the work ourselves so labor was free.
EDIT: x2 on that water pump and timing belt replacement. If you dont replace those two then it will most likely leak. ask me how i know
Old Apr 17, 2008 | 08:21 PM
v!taminb16's Avatar
Default Re: (EKstacy)
most likely it's the <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 &raquo;</TD></TR><TR><TD CLASS="quote">head gasket</TD></TR></TABLE>
Old Apr 17, 2008 | 08:22 PM
my car hasnt overheated or anything, well it hasent yet. and i do have a fuel leak and a wire was dissconnected. but the only big thing that it has had was a fuel leak from the injectors. and what do i look for on the radiator cap
Old Apr 17, 2008 | 08:31 PM
bump
Old Apr 17, 2008 | 08:34 PM
obuhmyuh's Avatar
make sure its intact, a faulty radiator cap can lead to an under-pressurized cooling system, which can lead to water/smoke spewing out your exhaust.
Old Apr 17, 2008 | 08:45 PM
Default Re: (obuhmyuh)
okay i will try that tomorrow. thanks alot. but any other advice would help
Old Apr 17, 2008 | 11:59 PM
bump
Old Apr 18, 2008 | 04:26 AM
[ivi]'s Avatar
The head gasket would produce BLUE smoke, NOT white. Your car would give you many symptoms if the headgasket is deteriorating. Like overheating, etc. Doesn't sound like your problem.
White (or gray) smoke is produced from an unhealthy fire from the cylinders. I suspect the wire that's loose is from one of the injectors. Can you take a snapshot of this loose wire?
It could be that somehow water is entering the intake. Make sure the diffuser isn't full of water, or your air filter isn't sopping wet.
Modified by [ivi] at 5:33 AM 4/18/2008
Old Apr 18, 2008 | 06:06 AM
geebs's Avatar
Default Re: ([ivi])
to ivi:
not to be an *** or a dick..
why only blue? blue is from burning oil.. which "could" be a result from a bad head gasket.. usually blue smoke is valve seals, guides, or piston rings... but coolant leaking into the cylinder from the headgasket will burn white..
let your engine get to operating temp and drop some antifreeze on your exhaust manifold.. what color does it burn?
to op:
do a compression check.. post your results.. open your radiator cap while the engine is warming up.. do you see lots of bubbles? are you low on antifreeze?
stock engine? stock ecu?
you have a gas leak.. thats not safe for you or your engine.. running lean kills engines. a fire hazard if its warm enough.. ive seen a fuel injector o ring go bad and gas leak enough to hit the alternator and ignite..
Old Apr 18, 2008 | 06:15 AM
[ivi]'s Avatar
Default Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">to ivi:
why only blue? </TD></TR></TABLE>
Just from my experience when my head gasket blew. I was told by a reputable Honda tech about the colors too, guess he's not so reputable now
Old Apr 18, 2008 | 07:14 AM
STDClayton's Avatar
Default Re: ([ivi])
White smoke = coolant burn
Blue smoke = oil burn
Old Apr 18, 2008 | 07:16 AM
ihrtjdmeg's Avatar
Symptoms of a blown head gasket.
Old Apr 18, 2008 | 07:44 AM
xlasianizelx's Avatar
are you sure about the colors?... recently i had white smoke and yes i was burning coolant, but now im burning oil and its still white smoke... my tail pipe smells like gas and my rear bumper is pitch black....
dont pay more than $500 for a headgasket job... its a 5-6 hour job and the gasket is only $30.... i did my own headgasket in only 1 day.. (9am - 4pm) all by my self.. but i did a wack job..lol
Old Apr 18, 2008 | 09:40 AM
obuhmyuh's Avatar
Default Re: ([ivi])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ivi &raquo;</TD></TR><TR><TD CLASS="quote">]The head gasket would produce BLUE smoke, NOT white. Your car would give you many symptoms if the headgasket is deteriorating. Like overheating, etc. Doesn't sound like your problem.
Modified by [ivi] at 5:33 AM 4/18/2008</TD></TR></TABLE>
oil and someimtes fuel is blue
Old Apr 18, 2008 | 09:44 AM
obuhmyuh's Avatar
Default Re: (xlasianizelx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlasianizelx &raquo;</TD></TR><TR><TD CLASS="quote">are you sure about the colors?... recently i had white smoke and yes i was burning coolant, but now im burning oil and its still white smoke... my tail pipe smells like gas and my rear bumper is pitch black....
dont pay more than $500 for a headgasket job... its a 5-6 hour job and the gasket is only $30.... i did my own headgasket in only 1 day.. (9am - 4pm) all by my self.. but i did a wack job..lol</TD></TR></TABLE>
why are you telling him it costs 500 bucks when you did it yourself. And changing a headgasket isn't something that should be a "whack job" there are so many things that can go horribly wrong if things aren't torqued down properly or are just put together half-assed. And like stated above and confirmed by other users, your water pump and timing belt should be replaced while you have this **** ripped apart.
Old Apr 18, 2008 | 10:29 AM
Default Re: ([ivi])
i do have a lose wire around my fuel rain. it could part of the reason. i will get a pic up asap
