iacv replaced still.......vid inside
Old Apr 17, 2008 | 04:42 PM
jdmland's Avatar
Default iacv replaced still.......vid inside
EDITED
New vid coming soon
Modified by jdmland at 3:11 PM 5/4/2008
Old Apr 17, 2008 | 09:36 PM
civicstar's Avatar
Default Re: iacv replaced still.......vid inside (jdmland)
this issue can be the cause of a dirty FITV, vacuum leak or a bad Fuel pressure regulator, had the same problem, turned out to be my fpr
Old Apr 17, 2008 | 09:39 PM
00b18b's Avatar
https://honda-tech.com/zerothread?id=1575913
Old Apr 18, 2008 | 02:25 AM
jdmland's Avatar
Default Re: (00b18b)
i have already replaced and cleaned the iacv, did the popcan trick on the fitv.
Still having the same prob?
jdmland's Avatar
Default Re: (jdmland)
Also vac reads 22 on the gauge so i'm good on vac leaks
Old Apr 18, 2008 | 11:57 AM
civicstar's Avatar
try checking the FPR, unplug the vacum on the fpr and let the fpr side open and the side on the intake plugged and see how it idles
Old Apr 19, 2008 | 08:37 AM
Ahknodd's Avatar
Default Re: (civicstar)
Probably a lame question, but what is the FITV? I've never heard that before. Thanks
Old Apr 19, 2008 | 09:39 AM
GhostAccord's Avatar
Default Re: (Ahknodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahknodd &raquo;</TD></TR><TR><TD CLASS="quote">Probably a lame question, but what is the FITV? I've never heard that before. Thanks </TD></TR></TABLE>
The FITV aka the Fast Idle thermal valve is used to adjust air into the intake when the engine coolant temp is blow a certain temperature. (Cold Weather Start) The FITV opens causing the engine to idle at a higher RPM, in turn it enables the engine to reach operating temperatures faster. As the coolant gets warmer the FIT valve closes and the IACV is in sole controls of idle adjustments.
Modified by GhostAccord at 2:48 PM 4/19/2008
Old Apr 19, 2008 | 01:40 PM
Ahknodd's Avatar
Default Re: (GhostAccord)
Sweet, thanks. Learn something new everyday!
likwidchz
Aug 25, 2008 09:48 PM
integra3586
Mar 10, 2006 10:17 AM
Stoich
Jul 26, 2005 12:27 PM
PowderB16
15
Mar 3, 2005 10:49 AM
blykins
Apr 30, 2004 02:29 PM
