h22a crank angle sensor
Old Jul 11, 2002 | 06:01 PM
22civic's Avatar
Default h22a crank angle sensor
do h22a have a crank angle sensor and if so does it effect vtec working. thanks
Old Jul 12, 2002 | 02:08 AM
kinesistech's Avatar
Default Re: h22a crank angle sensor (22civic)
obd2 engines have them near the crank. The earlier one have them in the distributor. Yes it can effect vtec, if its makes you have a check engine light.
Old Jul 12, 2002 | 07:09 AM
Mikey3000's Avatar
yeah it's in the dist on obd1. if you had a bad one you'd get a check engine light. if you're getting a cel for it, you'll need a new distributor. those sensors in the dist. can't be replaced by themselves.
Old Jul 12, 2002 | 09:28 AM
22civic's Avatar
Default Re: h22a crank angle sensor (kinesistech)
yea im getting a check engine light and my vtec isnt working. i didnt know it was in the dist. so i have to change the hole dist. will the vtec work again thanks.
Old Jul 12, 2002 | 09:32 AM
Mikey3000's Avatar
your car shouldn't even be running like normal. that's a pretty important sensor to say the least. i'm sure if you got a new dist. you'd be good to go.
note: don't buy a remanufactured distributor, they're junk. try to find a used one from someone if you don't want to spend $600 (i'm sure you don't).
Old Jul 12, 2002 | 09:37 AM
22civic's Avatar
Default Re: h22a crank angle sensor (Boss Hogg)
cool thanks then ill change the dist
preludecrazy
Jan 25, 2016 11:45 PM
customs-25
Jan 14, 2015 12:56 PM
AdamEG
Apr 18, 2012 11:15 AM
BowtieHonda
Mar 19, 2012 08:15 PM
SwappedLSHatch
Apr 13, 2006 01:33 PM
