exhaust question
Old Apr 17, 2008 | 11:04 AM
eglude's Avatar
Default exhaust question
i have a 95 dx hatch, exhaust system is stock. i found out that the exhaust is good but the pipes are beat up and i need to replace them. my friends told me might as well weld 2.5 inch pipe on it while im at it. my question is, what is that gonna do? should i do that?
sorry for the dumb question, im a newb at this. thanks in advance
Old Apr 17, 2008 | 11:12 AM
JesseBizz's Avatar
Default Re: exhaust question (eglude)
BOOOOP BOOOOOP it will be very loud personally 2.5 inch is too big but thats my option
Old Apr 17, 2008 | 11:15 AM
ddd4114's Avatar
If you're leaving the engine stock, 2" will be fine. If you're going to modify the engine (without turocharging/supercharging/nitrous-injection), use 2.25" piping. If you have a heavily modified atmo engine or one that is turobcharged/supercharged/sprayed, then you can consider piping that is 2.5" (or sometimes larger).
Old Apr 17, 2008 | 11:22 AM
eglude's Avatar
Default Re: exhaust question (ddd4114)
so my engine is a d15b, i have header, and intake. go with 2.25"?
Old Apr 17, 2008 | 11:27 AM
ddd4114's Avatar
2.25" will be fine. Keep in mind that a header and intake will not change the flow demand of your engine.
Old Apr 17, 2008 | 12:29 PM
eglude's Avatar
coo, thanks man. is it even a difference from stock (wat evr size that is) to a 2.25" in performance?
Old Apr 17, 2008 | 12:32 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eglude &raquo;</TD></TR><TR><TD CLASS="quote">coo, thanks man. is it even a difference from stock (wat evr size that is) to a 2.25" in performance?</TD></TR></TABLE>
barely, but yes
JoKarma's Avatar
Not really unless you're heavily modified. Good way to make your neighbors unhappy though.
Old Apr 17, 2008 | 12:33 PM
eglude's Avatar
good lookin out
andrey320
11
Nov 23, 2009 09:32 AM
FinallyGotMine
Jun 23, 2007 08:29 AM
GreenLS
Feb 23, 2005 04:34 PM
EG_93Civic
May 5, 2003 02:02 PM
accordfreak
Mar 12, 2003 09:42 PM
