Code 7 Throttle possition sensor
Old Apr 17, 2008 | 09:11 AM
Slammed_am's Avatar
Default Code 7 Throttle possition sensor
I just replaced my old Omni power USA TPS with a new one. After some testing it was determined that it was a dead spot in the TPS that cause the vehicle to "buck" at certain speeds. Ordered a new one from Omnipower, installed it in the 68mm Omni Throttle body thats been on the car and started it up. The car had a slight hesitation at first but then idled fine, then the check engine light came on. I checked out the plug on the TPS thinking I forgot to plug it in or something dumb and it was plugged in, and the 2 bolts on the TPS were secure as well. Started it up again, same thing. I decided to take it for a test drive and no more bucking like I was getting with the old one, and the car ran great...just with the CEL on. I Got home and jumpped the pins on the ECU and the code was 7 (TPS). The car is now sitting with the battery disconnected so I'm hoping maybe it just needed to be reset?
Does anyone have any additional input on this for me?
Thanks
roc0487
Dec 21, 2008 03:21 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
dabomb
Jul 14, 2003 10:15 AM
boyracer
May 9, 2002 05:44 PM
D1ANCER
Mar 27, 2002 06:06 PM
