Reuse Coolant?
Old Apr 17, 2008 | 07:22 AM
imzjustplayin's Avatar
Default Reuse Coolant?
I may need to drain coolant from my car because I would need to change the water pump, am I or should I reuse the coolant when I reassemble the system again? Do I have to buy new coolant once I drain it out? Also what is the proper disposal of coolant? Do I put it into any container and leave it at a place like goodyear?
Old Apr 17, 2008 | 02:01 PM
Perfectionist's Avatar
Default Re: Reuse Coolant? (imzjustplayin)
If the current fluid has been in there over 3 years, why not just replace it with fresh stuff after flushing the system? If it's fairly fresh, it can be reused as long as you use a clean container to collect it.
Yes, you can leave a container of used fluid at a place like Goodyear. Do it after they're closed though.
Old Apr 18, 2008 | 02:49 AM
Default Re: Reuse Coolant? (Perfectionist)
Why after they're closed? I dropped off a battery during service hours and it was a non issue..
Old Apr 18, 2008 | 03:55 AM
RS-2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imzjustplayin &raquo;</TD></TR><TR><TD CLASS="quote">Why after they're closed? I dropped off a battery during service hours and it was a non issue..</TD></TR></TABLE>
they take batteries, not fluids. and alot of places like to charge you or make you buy something or completly not take it.
i always get the envio-coolant or w/e that "green" coolant is...... not the color of the coolant green as in earth freindly so if i need to wash it down it isn't as harmful
b_serious
Nov 8, 2005 04:48 PM
Cypher0117
18
Sep 29, 2005 07:46 PM
Sassafrass
10
Sep 29, 2003 08:51 PM
benmasters
May 25, 2003 12:47 PM
JL 74
Mar 8, 2002 08:46 AM
