please help brakes tend to sink....
Old Apr 17, 2008 | 05:04 AM
project209's Avatar
Default please help brakes tend to sink....
my brakes tend to sink from time to time.. is my ABS messed up or do i need to bleed it again...please help
Old Apr 17, 2008 | 05:50 AM
H22Ej1's Avatar
Shenanigans
Default Re: please help brakes tend to sink.... (project209)
you probably have air in the system or are leaking fluid....look for any leaks around the wheels and check the fluid level. if you dont see nything bleed your breaks
Old Apr 17, 2008 | 10:12 AM
JDM Lyfestyle's Avatar
Default Re: please help brakes tend to sink.... (H22Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">you probably have air in the system or are leaking fluid....look for any leaks around the wheels and check the fluid level. if you dont see nything bleed your breaks </TD></TR></TABLE>
could also be bad fluid.contaminated etc
Old Apr 17, 2008 | 10:19 AM
[ivi]'s Avatar
Drain your brake fluid, re-fill, bleed, done.
Old Apr 17, 2008 | 11:51 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project209 &raquo;</TD></TR><TR><TD CLASS="quote">my brakes tend to sink from time to time.. is my ABS messed up or do i need to bleed it again...please help</TD></TR></TABLE>
look around the brake hoses and MC for leaks. if there are no leaks, booster could be going out. what year is your civic?
__oversea
Jul 6, 2008 07:51 AM
dumkopf
Mar 28, 2008 10:34 AM
faSHOwidIT
Apr 30, 2005 04:46 PM
J-g-D-s-M-r
Jul 29, 2003 04:20 AM
natrl
May 23, 2003 04:13 PM
