I have a check engine of speed sensor, I lost my vtec and my mph cluster doest work( my RPM is worki
Old Apr 16, 2008 | 01:58 PM
tegh22's Avatar
Default I have a check engine of speed sensor, I lost my vtec and my mph cluster doest work( my RPM is worki
I changed my speed sensor and i didnt have my Vtec also my mhp cluster...., does it have a link between these problem?
i have an acura integra 1994 with a prelude h22a 1993 block
and sorry for my english im form quebec city
Old Apr 16, 2008 | 04:11 PM
93PreludeVTEC's Avatar
Default Re: I have a check engine of speed sensor, I lost my vtec and my mph cluster doest work( my RPM is w
without a signal from your vss your vtec will not engage. are you sure you got the right vss and hooked it up properly?
Old Apr 16, 2008 | 04:27 PM
tegh22's Avatar
yes im sure i only need the wiring diagram from the speed sensor to the pcm with the color of the wire
Old Apr 16, 2008 | 07:23 PM
prelude_h22vtec's Avatar
shouldnt you check the diagram for an integra if thats the car you have it in?
but anyway, a usdm 93 prelude's colors for vss are:
black - ground
blk/yel - power
orn - signal
to find where it pins in the ecu search for an obd1 ecu pinout.
Beto760
Sep 7, 2010 11:00 PM
LS_Integra_94
Jun 12, 2007 05:31 PM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
94whitegsi
Aug 16, 2006 12:11 PM
freakasis
Apr 25, 2006 06:04 PM
