Odd Acting Tachometer, flashing radio and now no start up.
Old Apr 16, 2008 | 01:08 PM
rockcity's Avatar
Default Odd Acting Tachometer, flashing radio and now no start up.
Hi,
I have a 90 crx. On the way home today the tachometer dropped to zero and only registered RPMs when I pushed the clutch in. Then, the radio starting blinking on and off . When I got home I turned the car off and then tried it five minutes later. Now it won't crank at all. It sounds as if the battery is dead but the battery is only 3 weeks old. I push started it but it died after a few minutes. I don't understand how the battery could mess with the tachometer. How can I tell if something is draining the battery?
Thanks,
Jake
Old Apr 16, 2008 | 04:44 PM
rockcity's Avatar
Default Re: Odd Acting Tachometer, flashing radio and now no start up. (rockcity)
Update:
I took off the distributor cap and replace it tightly. I removed the battery cable and cleaned it throughly. I am certain that it is a dead battery because now it won't attempt to crank and the lights on the dash are very dim. The battery is almost brand new. How do I find out what is draining the battery?
Jake
Old Apr 16, 2008 | 06:44 PM
RanCRX's Avatar
Check if your battery negative ground wire is hooked up to your frame. My dumb *** had the same problem and one day I looked at my battery and noticed that I forgot to put a ground from the battery to the frame besides the engine. Stupid mistake but check. Trust me, it makes the lights dim, instrument panel, radio etc.
Old Apr 16, 2008 | 07:06 PM
rockcity's Avatar
Default Re: (RanCRX)
Hi,
Thanks for the reply. I have now checked the positive cable and the negative cable and all other grounds to no avail. Hmm...
niceprelude
Feb 26, 2017 08:03 PM
schueytenten
Oct 23, 2010 03:45 AM
fw190bvi
Jul 27, 2007 09:52 PM
wahee
Jun 2, 2006 02:06 PM
s2kkk
20
Apr 1, 2004 12:54 PM
