just replaced rod bearings, there is a small knock for about 3-5 seconds upon startup
Old Apr 16, 2008 | 12:59 PM
myEK=slow's Avatar
Default just replaced rod bearings, there is a small knock for about 3-5 seconds upon startup
any ideas? Like i said, started knocking so we towed it from the spot i started to hear it. pulled the oil pan to find i spun a rod bearing. crank looked and felt fine. we replaced the rod bearings and changed the oil a fews times. now when i start the car up, there is a knock for about 3 seconds and it goes away and all is well. i drove around the block and there wasn't any knock. oil pressure was fine. i cant think of anything?
plz help. thanks in advance.
Old Apr 16, 2008 | 01:25 PM
jewjew bean's Avatar
Default Re: just replaced rod bearings, there is a small knock for about 3-5 seconds upon startup (myEK=slow
did you plastigauge it?
Old Apr 16, 2008 | 01:54 PM
SPOOLINmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myEK=slow &raquo;</TD></TR><TR><TD CLASS="quote">any ideas? Like i said, started knocking so we towed it from the spot i started to hear it. pulled the oil pan to find i spun a rod bearing. crank looked and felt fine. we replaced the rod bearings and changed the oil a fews times. now when i start the car up, there is a knock for about 3 seconds and it goes away and all is well. i drove around the block and there wasn't any knock. oil pressure was fine. i cant think of anything?
plz help. thanks in advance.</TD></TR></TABLE>
I think your oil pump is taking a ****. My B18B has an old oem oil pump on it and when i crank it after sitting overnight there is a slight rod knock for about 1.5 seconds...who hasn't heard a honda do that though? I think its a weakening pump that can't flow enough at first crank.
Old Apr 16, 2008 | 02:02 PM
myEK=slow's Avatar
thats what we were thinking. oil pumps dont like ctr pulleys and thats what my car has now. I'm trying to get a gsr crank pulley. my oil pressure seems to be fine. any other ways of checking to see if its the oil pump.
Old Apr 16, 2008 | 02:34 PM
.adam.'s Avatar
time to pull your pan again lol
Old Apr 16, 2008 | 02:51 PM
myEK=slow's Avatar
****, i will pull my pan again if an oil pump will make everything better. lol.
Old Apr 16, 2008 | 03:26 PM
non-VTEC's Avatar
Default Re: (myEK=slow)
check the main bearings while you are at it. i bet you will find a few mains shot as well.
Old Apr 16, 2008 | 06:18 PM
Default Re: (non-VTEC)
man if thatshit knocks for just a couple of seconds everytime and then is perfectly fine and runs fine, then im sure its a crappy oil pump. what else could it realistically be.
Old Apr 16, 2008 | 06:26 PM
.adam.'s Avatar
ive searched some, and some ppl say they heard similar before a rod bearing went, but we just replaced them
Old Apr 16, 2008 | 06:27 PM
JoePSI's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myEK=slow &raquo;</TD></TR><TR><TD CLASS="quote">thats what we were thinking. oil pumps dont like ctr pulleys and thats what my car has now. I'm trying to get a gsr crank pulley. my oil pressure seems to be fine. any other ways of checking to see if its the oil pump.</TD></TR></TABLE>
CTR pulleys are notorious for creating unwanted vibrations in the oilpump.
Old Apr 16, 2008 | 06:34 PM
.adam.'s Avatar
we know this, thats why were hoping it the oil pump.....
Old Apr 16, 2008 | 08:12 PM
myEK=slow's Avatar
yeah. im thinking its the oil pump as well because it makes sense. when i first heard my car knock, we stopped and got out and inspected. i turned it over and back on again to hear the knock for a second and for the first couple seconds the knock was loud and got quiet. now that the rod bearings were replaced, the knock is loud for about 1-2 seconds and than it completely is gone. i drove the car around the block a few times and even popped into vtec and it still was fine. i let it cool for about an hour and started it back up, again, there was the knock for about 2-3 seconds and went away.
anyone else with info or ideas please post!
Old Apr 16, 2008 | 09:49 PM
Marlon88's Avatar
Your best bet is to take the pan/strainer/tray off and inspect all bearings and re torque them to OEM spec if you are still using OEM rods, if you`re using aftermarket rods make shure you torque them to manifucturer specs! Which rod bearings did you use? did you measure the crank where the rod bearing spun? Also what`s the story behind the spun rod bearing? because If your engine had a problem and it spun a bearing you just fixed the rod bearing, the problem why it spun is still there!
Old Apr 17, 2008 | 08:58 AM
.adam.'s Avatar
his problem is most likely the ctr pulley.....
Old Apr 17, 2008 | 12:01 PM
myEK=slow's Avatar
ugh im so nervous. i just want everything to be okay. lol
Old Apr 17, 2008 | 12:58 PM
change the pump!! Then go from there.
Old Apr 17, 2008 | 01:24 PM
myEK=slow's Avatar
yeah, im a little nervous. i started up the car today and let it run for a while, and everything was sound. than as i reved it a little on the throttlebody, i heard a different knock. guessing its a main bearing
Old Apr 17, 2008 | 04:56 PM
postman's Avatar
almost every make of car other than a japanese brand makes the same noise. i wouldnt be to worried
Old Apr 17, 2008 | 06:07 PM
myEK=slow's Avatar
Default Re: (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">almost every make of car other than a japanese brand makes the same noise. i wouldnt be to worried</TD></TR></TABLE>
Old Apr 17, 2008 | 07:54 PM
mike93eh2's Avatar
bearings.... plain and simple. whats with all the people saying its the oil pump.. lmao.
Old Apr 17, 2008 | 08:09 PM
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">bearings.... plain and simple. whats with all the people saying its the oil pump.. lmao.</TD></TR></TABLE>
say what you want but if a bearing was bad it wouldn't just knock for 3 seconds and be done.
Old Apr 17, 2008 | 08:14 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">
say what you want but if a bearing was bad it wouldn't just knock for 3 seconds and be done. </TD></TR></TABLE>
oh yea? why wouldnt it then huh?
are you talking with experience? ...because i sure am. the bearing(s) clearance is too loose and this is the sign of early bearing failure.
Old Apr 18, 2008 | 04:37 AM
are you talking with experience? ...because i sure am. the bearing(s) clearance is too loose and this is the sign of early bearing failure.</TD></TR></TABLE>
yes i have had bearings slightly knocking and couldnt figure out why EVEN after replacing all of them. Replaced the pump and FIXED. It could be either way.
teg gs
Sep 19, 2018 02:21 PM
iwannarace
10
Jun 13, 2015 06:14 AM
EFz6er
Jan 28, 2013 05:20 AM
leem23vtec
Nov 4, 2010 04:34 PM
qazaq
Dec 30, 2008 06:57 PM
