Toeque wrench for under the hood work?
Old Jul 11, 2002 | 04:09 PM
ragejed's Avatar
Default Torque wrench for under the hood work?
I need to get a torque wrench for some under the hood work. Like valve coer, etc. I know the valve cover needs 8lbs f torque. Where can I get an accurate torque wrnech that will do really low torque like this?
[Modified by ragejed, 1:09 AM 7/12/2002]
Old Jul 11, 2002 | 05:33 PM
Batoutahell's Avatar
Default Re: Torque wrench for under the hood work? (ragejed)
Don't use a torque wrench for such small amounts, ESPECIALLY the valve cover, as you will probably snap the bolts. Don't ask how I know this. Just snug them down with a small ratchet. You really don't need a torque wrench to work on the car until you get above 20 lb-ft or so.
Old Jul 11, 2002 | 06:47 PM
Farnsrocket's Avatar
Default Re: Torque wrench for under the hood work? (Batoutahell)
Go to Sears and get an inch lb. torque wrench.......12inch lbs. = One foot lb..............like $60 and well worth it
Old Jul 11, 2002 | 06:55 PM
02WRX's Avatar
Snap On makes a torque wrench that goes from 5 lb/ft to 75 lb/ft of torque - it's 3/8 drive. But, and this is a big but, it lists for $189 or so!
Eric
Old Jul 11, 2002 | 07:11 PM
Default Re: Torque wrench for under the hood work? (Farnsrocket)
Yes a small torque wrench is a very good investment. Still, I recommend against using it on your valve cover bolts. I have 4 torque wrenches, the smallest in lb-in, and I cringe at the thought of listening for the click (or snap), whichever comes first. Just snug them down with a small ratchet so we don't see as your next post "how do I extract a broken valve cover bolt?"
twkdCD595
Oct 22, 2021 02:10 PM
Rtboy10
Aug 29, 2010 09:25 PM
BB6racer
Jan 19, 2006 04:48 PM
4door_gsr_ftw
May 4, 2003 04:57 PM
capcon83
Mar 31, 2002 03:38 PM
