HOW DO I FIX THIS LEAK??!!
Old Apr 16, 2008 | 09:26 AM
xYoung s15's Avatar
Default HOW DO I FIX THIS LEAK??!!
hey guys..
alright i just bought this 99 accord and it has a little coolant leak. im pretty sure its not coming from the hose. so if anyone knows what i can do to fix this problem, please give me some insight.
here are some pictures:
any help is greatly appreciated
thank you
Old Apr 16, 2008 | 09:29 AM
bseriescrxsi's Avatar
Default Re: HOW DO I FIX THIS LEAK??!! (xYoung s15)
could be the heater core hose, or the temperature sending unit
Old Apr 16, 2008 | 10:54 AM
xYoung s15's Avatar
Default Re: HOW DO I FIX THIS LEAK??!! (bseriescrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriescrxsi &raquo;</TD></TR><TR><TD CLASS="quote">could be the heater core hose, or the temperature sending unit</TD></TR></TABLE>
where are those located and is it an easy fix?
Old Apr 16, 2008 | 12:13 PM
ronqqq's Avatar
Start the engine and build up pressure see if you can see where the leak is.... Looks like it is leaking around the coupling to the radiator hose. The evidence is on the bolt.
remove the two bolts and apply RTV on the surface.. Inspect the O ring and you could replace it..
The heater hose is under the dist , inspect it also..
Modified by ronqqq at 1:22 PM 4/16/2008
Old Apr 16, 2008 | 02:12 PM
accord99power's Avatar
i have to ask this whats the red wire for?
duffman1278
Sep 14, 2008 04:40 AM
perpetualburn
Nov 2, 2007 10:51 AM
ckur1y
Feb 15, 2006 06:41 PM
b18cEF9
Nov 5, 2004 12:44 PM
zort_zrt
May 25, 2004 04:15 AM
