E85 Build
Old Apr 16, 2008 | 06:35 AM
boostfed-r's Avatar
Default E85 Build
I am planning on running E85 soon and was woundering if stock FPR and Fuel Rail will work? I am running 1000cc's and 255lph.
Old Apr 16, 2008 | 06:38 AM
96 GSR-T's Avatar
typical vague question....... depends on the power level you are trying to achieve, but I would definately get a 1:1 Adj Fuel Press Reg.
Old Apr 16, 2008 | 06:57 AM
boostfed-r's Avatar
i run a jdm ITR Turbo with an sc34..looing to make around 315
Old Apr 16, 2008 | 09:14 AM
96 GSR-T's Avatar
Default Re: (boostfed-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfed-r &raquo;</TD></TR><TR><TD CLASS="quote">i run a jdm ITR Turbo with an sc34..looing to make around 315</TD></TR></TABLE>
you will be fine, get a FPR though
Old Apr 16, 2008 | 10:50 AM
HiProfile's Avatar
Default Re: (96 GSR-T)
Actually the stock FPR will be fine, just get a gauge if anything.
The reason it would work - with the same size pump, you bypass ~30% LESS fuel through the FPR. Given that a 255HP on a stock FPR only bumps if up ~10-15psi (~30% more), it should probably stay around stock if 30% more fuel is going through the injectors instead. Worst case you get a few extra PSI of fuel at idle, but you have to retune the entire map anyways.
Old Apr 16, 2008 | 11:43 AM
96 GSR-T's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Actually the stock FPR will be fine, just get a gauge if anything.
The reason it would work - with the same size pump, you bypass ~30% LESS fuel through the FPR. Given that a 255HP on a stock FPR only bumps if up ~10-15psi (~30% more), it should probably stay around stock if 30% more fuel is going through the injectors instead. Worst case you get a few extra PSI of fuel at idle, but you have to retune the entire map anyways.</TD></TR></TABLE>
yea, but I bet his high compression JDM ITR makes more than 315whp with that SC34 and E85, so why not just add the FPR, its not like it costs $400
2kdrift
Apr 10, 2013 12:16 AM
Sk8erlude
Jan 2, 2007 07:22 AM
DvD3
Nov 22, 2005 09:55 PM
ceemarun
May 29, 2002 02:18 PM
