b16a rods on b17 crank!!
Old Apr 14, 2008 | 08:48 PM
chuisek9's Avatar
Default b16a rods on b17 crank!!
would they work???by the way am trying to put civic type r piston and b16a rods and b17 crank on a b17 block which is the same as b16!
Old Apr 15, 2008 | 04:22 AM
chad's Avatar
Moderator
Default Re: b16a rods on b17 crank!! (chuisek9)
that combination won't work
Old Apr 15, 2008 | 05:11 AM
chuisek9's Avatar
Default Re: b16a rods on b17 crank!! (chad)
what would work?
Old Apr 15, 2008 | 02:08 PM
chad's Avatar
Moderator
b16a rods, crank, b16a/b17 pistons
b17 rods, crank, b16a/b17 pistons
all in a b16a or b17 block
nothing else will work except for a custom aftermarket application
Old Apr 15, 2008 | 04:42 PM
chuisek9's Avatar
ok thanks!!but can i put civic type r pistons??
Old Apr 15, 2008 | 06:08 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuisek9 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks!!but can i put civic type r pistons??</TD></TR></TABLE>
yes...
with b16 crank and rods you are gonna be at almost zero deck
with b17 crank and rods you are gonna be sticking out of the hole!!!
better make sure you know what you are doing!
executedace
Jun 5, 2010 11:27 PM
Bsixteen_CRX
33
Nov 26, 2007 07:42 PM
B16b2b
May 17, 2003 06:59 AM
Deltax75
May 20, 2002 09:03 AM
BoostedSi
Apr 25, 2002 01:50 PM
