Twin Scroll Manifold Single Wastegate Question
Old Apr 14, 2008 | 03:16 PM
Mr. Lucky's Avatar
Default Twin Scroll Manifold Single Wastegate Question
what would be better for a single wastegate setup, 1-2 and 3-4 runner coming together or 1-4 and 2-3? would it make a difference?
Old Apr 14, 2008 | 06:20 PM
HiProfile's Avatar
Default Re: Twin Scroll Manifold Single Wastegate Question (Mr. Lucky)
1-2, 3-4 would be worse than a undivided manifold, as far as power goes. The goal behind dividing them is to prevent the exhaust event from coinciding with an overlap event.
To make a long story short, there's only two things special a single wastegate on a divided setup should have: a low backpressure dump tube, and for the WG runners to be divided as long as possible (up to the valve if you can).
Old Apr 14, 2008 | 06:33 PM
Mr. Lucky's Avatar
Default Re: Twin Scroll Manifold Single Wastegate Question (HiProfile)
thanks for the reply. the reason i was asking is because there was one that i saw that had a 1-2 3-4 setup. we're on the right track.
Civic89stdB16
Jan 25, 2009 11:38 AM
Ak_ef9
Dec 30, 2006 09:04 AM
IntegraMastaz
Feb 8, 2006 09:33 AM
