Cast manifold Question
Old Jan 25, 2009 | 03:27 AM
Civic89stdB16's Avatar
Default Cast manifold Question
Hey i just got my cast manifold and the hole for the 38mm wastegate is not 38mm. Do i need to dremel it out to the 38mm or can i leave it alone. Its only a little bit smaller. thanks
Old Jan 25, 2009 | 04:34 AM
Mr. Em1's Avatar
Default Re: Cast manifold Question
it is probably set up for a 35mm wastegate, alot of the older kit ran 35mm tials, you should be fine if you leave it but if you want you can take off the 3mm
Old Jan 25, 2009 | 04:41 AM
ok thanks
Old Jan 25, 2009 | 08:17 AM
stockb18c's Avatar
ya i said the same thing like wtf but forgot the 35mm setup and i just stuck it on there and dealed with it and it does fine
Old Jan 25, 2009 | 08:25 AM
thanks guys. im going to dremel it out so its 38mm.
Old Jan 25, 2009 | 10:31 AM
HiProfile's Avatar
The venturi effect allows the same amount of air to exit a 35mm hole as does a 38mm hole, only with a little more speed. I'm guessing the restriction is all of 1/2" long total. Its really a smaller WG valve, narrow & long pipes feeding the WG, and (most important) wastegate location that will lead to boost creep on a cast mani.
If you plan on running a stright T3 on a 2.0L you'd want to grind it out, otherwise its just a 1/2 hour of dirty work to feed your peace-of-mind.
Old Jan 25, 2009 | 11:38 AM
yeah its between port 2 and 3. im just going to grind it out. thanks guys.
Hybrid96EK
Sep 17, 2009 03:01 AM
homicydalboy
Jun 4, 2007 06:12 PM
zulustypes
Jan 26, 2005 02:52 PM
Spooled1.6L
Feb 21, 2004 08:23 AM
