Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spring rates? Pics inside
Old Apr 14, 2008 | 09:32 AM
rustlude87's Avatar
Default Spring rates? Pics inside
Car-1987 Prelude Si
The problem I'm having is right now I have intrax 2" lowering springs and I calculated the rates to be 350 front and 250 rear, but the rear is so soft it tends to squat really bad
I just feel like this is slowing me down a little. What I was thinking of doing is buy a set of coilovers.
Setup:
KYB GR-2 (front)
Koni Red (rear)
Intrax 2" lowering spring
Koni front and rear sway bars
You guys have any suggestions for stiffening this car up?
Old Apr 14, 2008 | 10:14 AM
kommon_sense's Avatar
Default Re: Spring rates? Pics inside (rustlude87)
Considering that the car is >20yrs old, how old are the bushings? I would attack them first.
Old Apr 14, 2008 | 10:24 AM
rustlude87's Avatar
Default Re: Spring rates? Pics inside (kommon_sense)
Well I do have poly bushings sitting on my desk right now for the front, no one makes them for my car
But the problem must be the springs, when the car is sitting the back sits lower (and it looks really bad too)
Old Apr 14, 2008 | 11:47 AM
JW racing's Avatar
Slip on ground controls, with stiffer springs may help
Old Apr 14, 2008 | 11:59 AM
rustlude87's Avatar
Default Re: (JW racing)
thats what I was thinking, but I need the find out what the spring rates are for the 94-01 integra are
Old Apr 14, 2008 | 12:27 PM
jbs's Avatar
jbs
Default Re: (rustlude87)
my first suspension were GC coilovers and tokicos. the springrates were about the same as yours. i used a 22mm sway and tire pressure to make up for the spring rates. just a suggestion. as a note, its ok for autox not for road racing b/c the rear tire will fold over.
Old Apr 14, 2008 | 12:32 PM
kaiba's Avatar
Default Re: (jbs)
Should a car with rust really be use to autox. Shouldn't the chassis be fairly weak already????
Old Apr 14, 2008 | 12:41 PM
rustlude87's Avatar
Default Re: (kaiba)
its just the outer panels so it really does make a difference, frames good thats all that matters
Old Apr 14, 2008 | 02:44 PM
Crazydave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rustlude87 &raquo;</TD></TR><TR><TD CLASS="quote">Car-1987 Prelude Si
I just feel like this is slowing me down a little. </TD></TR></TABLE>
You can start to speed up by loosing the passenger (unless he is an instructor).
It looks like a good 250lb to be lost there.
how would you like you car to handle..... other than it appears to squat... what do you want to correct ?
Old Apr 14, 2008 | 04:26 PM
climb_on's Avatar
Default Re: Spring rates? Pics inside (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">
x2
i was thinking the same thing as i scrolled down you beat me to it!
that passanger looks like a hefty guy! easy weight reduction.
Old Apr 15, 2008 | 05:42 AM
GI8U2racing's Avatar
LOL, your head is sticking out the sunroof
Answering your question: GC 400f/500r with your shocks, and ditch those bushings, you'll have fun with that
Old Apr 15, 2008 | 10:04 AM
rustlude87's Avatar
I think I'm going to get springs rates like 450f/ 500r
And yes my head goes out the sunroof!!
88LXi68
Suspension & Brakes
18
Aug 8, 2018 11:13 AM
mazdabish
Suspension & Brakes
Feb 20, 2015 10:31 AM
EK4civichatch
Suspension & Brakes
Jan 28, 2005 10:01 AM
VTEConly
35
Jul 22, 2003 08:49 AM
BD7581
Aug 3, 2002 09:40 PM
