Need help!!Code 15
Old Apr 13, 2008 | 03:42 PM
hatchaddict's Avatar
Default Need help!!No power to the distributor
A friend of mine came and tested everything and said there is no power to the distributor.I changed distributor and ecu from a running car,checked fuses,switched main relay.So the car just cranks over but doesn't want to start.What else can I do.Sorry vehicle is a 93 hatch Vx
Modified by hatchaddict at 2:50 PM 4/20/2008
Old Apr 13, 2008 | 03:48 PM
Frickr's Avatar
Default Re: Need help!!Code 15 (hatchaddict)
http://www.clubsi.com/error_codes.shtml
heres all the codes, there is no code 15.
Old Apr 13, 2008 | 04:29 PM
Ignition output signal.I did some searching already.Anyone?
Old Apr 13, 2008 | 05:27 PM
Old Apr 13, 2008 | 07:42 PM
any1
Old Apr 13, 2008 | 08:47 PM
slammedvtec's Avatar
try checking your fuses i had that code recently, and it just went away by taking my ecu out of the car for a day and putting it back in it was weird. that and i also hear main relay will throw that code? dont quote me but ive read it on a couple of forums now.
Old Apr 16, 2008 | 10:31 PM
Default Re: Need help!!Code 15 (slammedvtec)
Koo thx I'll try that..
Old Apr 19, 2008 | 07:52 PM
Anyone...please help....need to get this damn car to start
Old Apr 19, 2008 | 08:04 PM
Luserkid's Avatar
Check your ign. power coming from the key cylinder (blk/wht wire) and your ecu ignition output wire (A15, not sure off top of my head) yel/grn. With key ON both should have batt volts.
Old Apr 20, 2008 | 01:52 PM
Default Re: Need help!!No power to the distributor (hatchaddict)
anyone
Old Apr 20, 2008 | 10:42 PM
Someone gotta know.
901Accord
Jun 7, 2017 02:22 PM
xwhitchx
Jan 7, 2012 03:41 PM
dfbdavid38
Dec 24, 2010 12:41 PM
ketchup214
Apr 17, 2010 03:03 PM
slammedvtec
Apr 17, 2008 02:17 PM
