brake issue
Old Apr 13, 2008 | 03:11 PM
higgunscrx's Avatar
Default brake issue
my crx back passenger side brake is dragging, mostly when i turn left, if i'm going straight it doesnt do it as much and when i turn right it doesnt do it at all. its not dragging alot but just enough to be annoying. doesnt make any noise when i brake either.
anyone know whats the problem? i was just gonna take my caliper off and lubricate the guide pins, but i couldnt loosen the bolt. it was siezed. gonna buy a air rachet hopefully soon to take it apart without stripping the head of the bolt.
suggestions?
Old Apr 15, 2008 | 11:53 AM
higgunscrx's Avatar
no one??
Old Apr 15, 2008 | 01:25 PM
mini-me-power's Avatar
Are you sure its dragging and it might not be the backing plate or something else?
Old Apr 15, 2008 | 05:23 PM
fun4door's Avatar
i would also check your wheel bearing, to me, i think that's where your problem might be...
Old Apr 15, 2008 | 05:56 PM
Crx Jimmy's Avatar
Default Re: (fun4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fun4door &raquo;</TD></TR><TR><TD CLASS="quote">i would also check your wheel bearing, to me, i think that's where your problem might be...</TD></TR></TABLE>
bingo the hub is moving slightly, probably due to a bad bearing causing it to rub while going in one direction only. sounds like the culprit
Old Apr 16, 2008 | 02:28 PM
higgunscrx's Avatar
ok but it doesnt make the noise when i brake, turning in any direction.
Old Apr 19, 2008 | 02:28 AM
fun4door's Avatar
thats because when you brake it relieves the bearing of the wieght and now your hub is actualy floating...
Narcotic_y2k
Sep 18, 2005 09:33 AM
sb
Aug 4, 2005 07:19 PM
.M.
May 19, 2005 01:03 PM
ThrashSM
Aug 11, 2004 05:03 PM
