SoCal Area Track Car Roll Call
Reading H-T, it never seems to amaze me how many serious track cars there are in and around SoCal. Many of them, I've never seen.
It occurs to me that there may never be "one event" that could draw all these cars out to. Likewise, its unlikely we'd all have them running at the same time. Or be able to pay for gas and track fees on the same weekend. So I thought it'd be cool to start a SoCal area track car thread just to see what's in the area...
Please post photos, snaps and info if your car fits any of the following descriptions:
• Competes in SCCA
• Competes in NASA
• Competes in Time Attack
• Needs a trailer because its not legal to drive
• has a full cage
• over the last two years has been driven more miles on the track than on public roads
• possesses some other characteristic that makes it a TRUE track car (rather than just a car you track)
• has actually BEEN to the track (and isn't still in the project stage...)
Here's mine:
NASA H2 and E1 (enduro)
Race Car Description: 1991 Honda Civic Hatchback
Original owner car purchased new by Thawley while in college at Art Center College of Design. The car has been the subject of a number of tech and race stories throughout the years and has seen prior coverage in Sport Compact Car, Super Street, Turbo magazines as well as countless appearances on popular import web sites.
Build Philosophy: Simple, Dependable, Consistent
Honda has many millions of dollars and billions of miles in research and development this chassis and drivetrain. We believe Honda OEM parts are among the best in the world. We look to the aftermarket only when certain factory parts have proven inadequate for racing use.
Chassis:
• 2250 lbs minimum weight (with driver)
• Steel unibody with custom bracing, integrated roll cage and door bars
• Custom aluminum air-dam with Alumalite splitter and undertray
• G-Stream composite rear wing
• RacePak G2X data logger
• AutoMeter instruments
• Cobra FIA-spec seats
• Safecraft SFI driver harness, inside head restraint net and 10lb Halon fire system
• NRG lightweight race battery
Suspension:
• Double wishbone strut with monoball suspension bushings
• Koni/PIC adjustable shocks (depending on track and setup)
• Hypercoil race springs
• Progress Technology adjustable, rear anti-roll bar
• Fastbrakes/Wilwood 4-piston front brake calipers with vented 11” rotors
• Fastbrakes/Wilwood 2-piston rear brake calipers
• Hawk Performance brake pads
• 15x7 aluminum wheels
• 225/50-15 DOT competition tires
• SPC components for camber and alignment adjustments
Drivetrain:
• Honda B20 block & cylinder head
• Blox performance intake manifold
• AEM cold air intake
• Fluidyne heavy duty aluminum radiator
• Tru-Cool oil cooler
• Walbro high pressure, high volume fuel pump
• Tuner Toys 310cc fuel injectors
• Brian Crower valve springs & titanium retainers
• Hondata S-300 engine management
• Engine tuning by Church Automotive Testing
• ACT heavy duty clutch & pressure plate
• ACT Prolite flywheel
• Raxles competition axles
• Competes in SCCA
• Competes in NASA
• has a full cage
Here's mine:
Chassis:
Suspension:
Drivetrain:
This is my new racecar.
1993 Integra:
Was running ITA in nor-cal. As far as I can tell its pretty built, feels fast. Not sure on mods on motor. 500f 1300r springs. Tokiko Illumina (F) AD (R). Hideous yellow interior.
Comming to H4 HC in 09...
Will also run in Time Attack.
Some Pic's
1993 Integra:
Some Pic's
First of all, nice wing John, you tryin to compete with us on the highest wing? J/K
91 NSX Redline Time attack and super lap battle series
Unlimited Clas
More power than we know what to do with.....(we started out as drag racers
Radar absorbing black
Based out of Las Vegas..
mikey
Unlimited Clas
)Radar absorbing black
mikey
Nice Photos some has been photog must ahve taken those
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley »</TD></TR><TR><TD CLASS="quote">
Car:
1994 Honda Civic Si
Charcoal Gray (well oxidized)
Engine
D16z6 recently rebuilt with .25mm overbore
1" port mached on intake
Entire rotating assembly balanced
Suspension
Koni Yellow OTS
Ground Control 450fr 600r
Stock Front Bar
No Rear Bar
Interior
Gutted (except CD player, stereo, heater, and Dash)
Photos
photo credit: Phil Gibbs
This is a track/street car.
The most street time it saw this year was to drive to California Speedway.
The most street time it saw last year was on and off the trailer at Buttonwillow, and to bed in my brakes.
Coming soon.....
Roll cage & Seat
Koni revalves & Stiffer springs
Tires & Wheels
1994 Honda Civic Si
Engine
Suspension
Koni Yellow OTS
Stock Front Bar
No Rear Bar
Interior
Photos
Coming soon.....
Roll cage & Seat
Tires & Wheels
Here is mine, nickname the xmas hatch...
93 Honda Civic Si Honda Challenge H2 / Track Events / Money Pit
Im just finishing rebuilding it...
Red & Green (ie the xmas hatch)
b16a to H2 class spec
GC 600/800 w/ tophats and revalved Bilstens
21mm F/R swaybars
wilwood brakes
custom cage, etc
Yes, i did the painting myself. Turned out really well. I tried to match Kawasaki Green.
21mm F/R swaybars
wilwood brakes
custom cage, etc
I'll post my money pit. Occasional auto-X and HPDE duty.
1995 Honda Civic Si
Engine:
D16Z6
- 10.4:1 Compression
- Zex Cam
- P&P head
- ARP head studs and rod bolts
- B16 throttle body
Transmission:
SI
- Quaife ATB
- SRR 4.9 FD
Suspension:
- H&R Cup Kit (H&R springs with rebadged Koni shocks)
- Type R rear sway bar
Brakes:
- Fastbrakes 11" fronts
- Stock rears
Wheels:
- 15" Rota Circuit 10 (Sport Bronze)
- Falken Azenis 205/50/15 (like everybody...lol)
NO A/C
NO P/S
NO Stereo
Tuned with Crome by Church @ only 6 psi...
1.
2.
[B]3./B]
4.
1995 Honda Civic Si
Engine:
D16Z6
- Zex Cam
- P&P head
- B16 throttle body
Transmission:
SI
- Quaife ATB
- SRR 4.9 FD
Suspension:
Brakes:
- Stock rears
Wheels:
NO A/C
NO P/S
NO Stereo
1.
2.
[B]3./B]
4.
About to come out in SO CAL H1 any minute now once I get a few bugs in the car worked out. Hope to run a few Time Attack events as well.
Too much to list-
NASA Spec cage
Full Progress suspension
Gear- X Final Drive
Clutchmasters clutch
Advanced Street Performance Header and exhaust
Rota Wheels
All work done by me in my garage
This car has seen 8 track days in 2007 with a GSR engine and over the winter got a new engine, added a cage and safety items and painted it. Did one lap at California Speedway in March with an axle issue. Looking forwad to getting it dailed in at the next event and hopefully get racing soon.
Too much to list-
NASA Spec cage
Gear- X Final Drive
Rota Wheels
here's mine.. nothing special, just the basics, as it seems I prefer tracking it more than modding it (laziness). but it's been my track ***** for the last few years.
NASA H2/PTC
1995 HONDA CIVIC SI
B16 ENGINE
ITR TRANNY
PIC SUSPENSION
ITR BRAKES
CAR WAS BUILT WITH "KISS" PHILOSOPHY IN MIND
car hasnt been doing too well lately, but will be back next month for the night enduro at phoenix and then miller motorsports in june-
hope to see so cal duders at miller!
1995 HONDA CIVIC SI
B16 ENGINE
ITR TRANNY
PIC SUSPENSION
ITR BRAKES
midngn
Sep 6, 2005 04:15 AM
then
