Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Adjustable UCA
Old Apr 13, 2008 | 02:56 PM
ED9man's Avatar
Default Adjustable UCA
I have an 88 CRX and I am looking for a front upper control arms to dial in more camber. Just looking for recommendations. Thanks.
Old Apr 13, 2008 | 04:19 PM
climb_on's Avatar
Default Re: Adjustable UCA (ED9man)
i used the wicked tunning rear uca camber kit and having great sucess with it. for the price im planning on going with their front uca kit also.
they don't campare to the skunk2 race model design wich completely elimnates the problem of bending the track that the ball joint moves on.
some simple fabrication can eliminate this problem on the cheaper models like the wicked tunning (also blox and omni)
the wicked tunning front uca are under $90
(this isn't refering to their spherical bearing units)
If you have the cash go with the skunk2 race models or the spc full uca.
Old Apr 13, 2008 | 05:39 PM
dirty19's Avatar
Ridin Dirty in Cali
I use the omni power adjustable UCA's
Old Apr 13, 2008 | 10:29 PM
GI8U2racing's Avatar
Default Re: Adjustable UCA (climb_on)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on &raquo;</TD></TR><TR><TD CLASS="quote">If you have the cash go with the skunk2 race models or the spc full uca.</TD></TR></TABLE>
I am between these two. Is there an SPC model that has everything included? I see no "full" UCA for a CRX on their site at least. I only see the anchor bolts and the ball joint.
The Skunk2 Pro (not Pro+ because it's not available for EF's) seems like an easier choice at the moment...but the bushings suck
I want spherical, but will settle for poly bushings at the top, and a very nice ball joint at the end of the arm, anyone have that?
EDIT: I found these, but not for EF's: http://www.spcperformance.com/...&cmd3=
That is a good start, but I assume it's trashy bushings anyway...
Modified by GI8U2racing at 4:28 AM 4/14/2008
Old Apr 14, 2008 | 06:42 AM
ekim952522000's Avatar
Default Re: Adjustable UCA (GI8U2racing)
I like Skunk2's new one.
Old Apr 14, 2008 | 06:52 AM
climb_on's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by GI8U2racing at 4:28 AM 4/14/2008</TD></TR></TABLE>
spherical are nice but would bump me out of sts so for me at least its not a choice, not sure if it matters to the op tough.
i guess spc only makes their full uca for integras and later model civics.
Old Apr 14, 2008 | 08:10 AM
R you serious's Avatar
Default Re: Adjustable UCA (ekim952522000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">I like Skunk2's new one.
i use these and reallly like them- but they kill on your PT points!
Old Apr 14, 2008 | 01:19 PM
FlyZlow's Avatar
Default Re: Adjustable UCA (R you serious)
I use the Ingalls adjustable mounts because they allow you to keep the stock UCA and you don't have to worry about the ball joint coming loose if it hits the inner fender or anything. Plus, the race spec ones give you a hard race surface at the mount bushings, so IMO it's a win-win.
Old Apr 14, 2008 | 02:59 PM
Phoenix_ITR's Avatar
the skunk2 adjustable UCA combined with the orijin bushings seems like it would be a good compromise.
Old Apr 15, 2008 | 02:03 AM
Default Re: Adjustable UCA (Phoenix_ITR)
Yeah, that's what I was afraid of...
Old Apr 15, 2008 | 09:19 AM
slammed_93_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, that's what I was afraid of...</TD></TR></TABLE>\
there is a guy on here "renegade" or something that sells SB upper things.
Old Apr 15, 2008 | 04:54 PM
ED9man's Avatar
Default Re: Adjustable UCA (FlyZlow)
Ingalls makes 2 kits. 0 - 1.5" drop and 1.5 - 3.0" drop. Do those two provide a couple degrees of adjustment in the negative range with the drop they correspond to? I am lowered a couple inches.
Old Apr 18, 2008 | 10:06 AM
Lo-Buck EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">
i use these and reallly like them- but they kill on your PT points! </TD></TR></TABLE>
HC=points free
bmoua
Mar 26, 2008 10:37 AM
vaajboy
Sep 15, 2005 01:06 PM
BoOsTiN Dc2
Suspension & Brakes
Sep 8, 2005 04:49 AM
Bills01ITR445
May 20, 2004 11:45 AM
thaiphob
Oct 28, 2003 07:55 AM
