running power wire from the battery?
Does anybody know a good place to run the power wire from the battery to the trunk? I can't seem to find a hole from the firewall.... on a 93 civic hatch.
Use the big fat grommet for the ecu wires....poke a hole in it and pull the wire through.
If you drill a hole, you have to use a rubber grommet anyway, so why not just use whats there?
My EJ had a fire wall plug just below the battery, with nothing there. The cable dropped in behind the glove box, and i ran it down the door channel, behind the back seat, to the trunk.
i drilled a hole right behind my battery and sealed it with silicone, then i ran the wire down my console since it was the easiest to get off, under the carpet and rear seat. it looked professional all except for the hole i drilled but the battery hides it
fast90hatch
150
Oct 10, 2008 10:56 PM
