Help repair
Old Apr 13, 2008 | 09:55 AM
sde780's Avatar
Default Help repair
Can someone tell me all the part's I'll need to fix this? Thanks
Some website that sell the parts needed would really help too,
all the damage:
Hood:
Parts that fell off:
Old Apr 13, 2008 | 11:58 AM
greyeghatch's Avatar
Default Re: Help repair (sde780)
that hurts ur best bet is to jus fix it dont look that bad
Old Apr 13, 2008 | 12:32 PM
v!taminb16's Avatar
Default Re: Help repair (greyeghatch)
just get a new front end bumper suport bumper hood light's the work's
Old Apr 13, 2008 | 02:34 PM
sde780's Avatar
the part where the bumper support bolts onto the rad support or whatever, it's bent. So I doubt a new bumper support will fit. Can I just hammer the thing till it fits?
Also, my radiator mount thing (ball-like thing at the bottom, above the scuff plate) is a bit loose and not straight, should I get a new one or is it ok if it's just a tad angled?
Old Apr 14, 2008 | 03:30 PM
sde780's Avatar
Bump
Old Apr 14, 2008 | 04:06 PM
hondabadtoy's Avatar
Default Re: (sde780)
new front end support - find a junked model to salvage the support
check the hood hinges, are they bent and not the hood itself?
new headlights
side markers look alright correct?
new bumber cover and ur good.
try http://www.partstrain.com or even ebay.
Old Apr 17, 2008 | 07:22 PM
sde780's Avatar
Default Re: (hondabadtoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabadtoy &raquo;</TD></TR><TR><TD CLASS="quote">new front end support - find a junked model to salvage the support
new headlights
try http://www.partstrain.com or even ebay.</TD></TR></TABLE>
Hood hinges are bent/cracked
Only one headlight is cracked
What are side markers? the little rectangular yellow thing that lights up, on both fenders or doors? I don't have those on my car...
I'm worried that the support won't bolt on, because the part where you bolt it to is bent like an inch out, and an inch in on the other side
Old Apr 18, 2008 | 11:10 AM
komat's Avatar
go to http://wvmotorsports.com pm partsman
he can get you the parts for decently priced. you can also maybe get him to come check it out to see what you all need
Old Apr 18, 2008 | 12:52 PM
the hinges are probably whats flexing the hood then. Sorry lol i was thinking it was an older car for sum reason, your side markers are your turn signal housings but they are built into ur headlight assembly so ur good there. If u can find a laser alignment shop near u theycan pull the front support back to factory specs. Now all u need is a bumper cuz the grill looks fine.
Old Apr 30, 2008 | 04:35 PM
sde780's Avatar
Haha I fixed the grille myself, I asked around and they said it'll be about $800 to fix everything, but they can't just fix the front support, they have to provide all the parts.
Komat, thanks for the tip I'll talk to him right now
Mr. EJ1
Paint and Body
Apr 29, 2009 09:22 PM
halozero
Jul 23, 2005 12:43 AM
vxnine
Oct 18, 2004 10:23 PM
Lost Type R
Aug 8, 2002 11:39 PM
