Uh oh.......Installed some GlowGauges on my Cousinz car but Now the Speedo dont work?
Hey guys, my cousin asked me to help her install some Glow Gauges she bought For her Integ, but the Damn thing didn't come with any instructions ...but anyways I installed them with a little help from the Internet haha....Everything works fine but now the Speedo doe sent work???
Note: I did take out 2 screws on the back of the GaugeCluster behind the RPM gauge BUT i forgot to take them out for the Speedo.....could that be the reason why its not working??........Is there any way to fix it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter »</TD></TR><TR><TD CLASS="quote">Did you have to pull off the needle to install the ricer mod? If so, you need a new speedo.
(serious)
-Rik</TD></TR></TABLE>
its for a girl that's a ricer. shouldnt you spare her ?? lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX »</TD></TR><TR><TD CLASS="quote">
Note: I did take out 2 screws on the back of the GaugeCluster behind the RPM gauge BUT i forgot to take them out for the Speedo.....could that be the reason why its not working??........ </TD></TR></TABLE>
if you messed with screws to put the gauge faces, im pretty sure that is your problem. if your saying your needle doesnt move at all well then you messed around and i would recommend to buy a new speedo.
(serious)
I don't care if you all consider it Ricer, she just wanted it to look pretty, And it looks pretty nice at Night.....anyways The RPM works fine its just the Speedometer that doesent move....
Also: I didn't take off the needles I Slid the gauges in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Does the needle move freely by hand? Does the odometer work?</TD></TR></TABLE>
yea it does.... but the odometer doesent work
yea it does.... but the odometer doesent work</TD></TR></TABLE>
im guessing you did damage it, there cannot be another explenation. Seriously, maybe you did mess it up on ACCIDENT, the gauge faces shouldnt have any effect unless they cant let needle move freely. but you have confirmed you can move it with your hand, so im guessing she or you or somebody needs a new speedo.
was it easy to replace? what wires did you unplug to perform the installation?
I would check the speedo cable in the in the dash to the instrument cluster.
then check the speedo cable to the transmission make sure its plugged in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projsectEF »</TD></TR><TR><TD CLASS="quote">was it easy to replace? what wires did you unplug to perform the installation?
then check the speedo cable to the transmission make sure its plugged in.</TD></TR></TABLE>
amigo amigo, he said they are gauge faces not a whole cluster mod.
What year is the Integra?
If it is 94+, check the wiring to the speedometer, green film, etc.
If it is 93-, check the speedometer cable connection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projsectEF »</TD></TR><TR><TD CLASS="quote">oh my bad. i guess the whole cluster doesn't need to come out then. never mind then.</TD></TR></TABLE>
well you do take out cluster and remove the glass so that you install the gauge faces. the only wiring you really do is connect the faces to switch so that they light up.
as you can see in the picture i provided, i had to remove plastic glass in order to install gauge faces.
If it is 93-, check the speedometer cable connection.</TD></TR></TABLE>
x2 im thinking this for a DA...if so you just didnt get the speedo cable back into the hole on the cluster, if this is for a 90-93 teg then you going to have fun getting that cable back into socket bc there isnt much play in the cable or room to get your hands back there.
Hers is a 95+ integra...... gotta wait till she comes back from Davis in order to look at it again.... So theres no way to fix it huh, besides buyin a whole new cluster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX »</TD></TR><TR><TD CLASS="quote">Hers is a 95+ integra...... gotta wait till she comes back from Davis in order to look at it again.... So theres no way to fix it huh, besides buyin a whole new cluster?</TD></TR></TABLE>
by reading what you said, that it messed up right after thet gauge face installation, yes its messed up. should be replaced
Powered by VTEC
Jan 26, 2008 09:03 PM
