HOw to install Gauges????
Old 09-28-2004, 11:41 AM
92_EGhatch's Avatar
Default HOw to install Gauges????
hey can someone help me out....i have two guages, an oil pressure and water temperature....i got the pod and everything but just need to know if someone can help instruct me to installed it.....all i know is that one is an electrical and the other one is mechanical....please help me....
92_EGhatch is offline
Old 09-28-2004, 11:53 AM
Luserkid's Avatar
Default Re: HOw to install Gauges???? (92_EGhatch)
If you were in So. Cal i could install them for you. Its pretty easy. First off which is mech. and which is electric?
Luserkid is offline
Old 09-28-2004, 12:12 PM
Default Re: HOw to install Gauges???? (Luserkid)
not tryin to flame you or anything. but gauges do come with instructions correct?
fantabulous is offline
Old 09-28-2004, 12:29 PM
92_EGhatch's Avatar
Default Re: HOw to install Gauges???? (fantabulous)
YEs... they do come with instruction but in this case the instruction is not helpful and there is no diagram for u to use as visual aide.
Old 09-28-2004, 12:34 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">If you were in So. Cal i could install them for you. Its pretty easy. First off which is mech. and which is electric? </TD></TR></TABLE>
Luserkid: Do you think you could answer my questions about guages in this thread?
https://honda-tech.com/zerothread?id=709396
Sorry to hijack, but I thought the thread might help the original poster as well.
AutoXer is offline
Old 09-28-2004, 12:35 PM
if the water temp sensor is made for ur car, the sender should screw into the hole where the radiator drain plug is. then you just have to wire for the lights on the gauge i think. then find your oil pressure switch, the gauge should come with adaptors to tap into the line. mine didnt, i found these at home depot for under 10 bucks. other than that, just wire for the back light for the gauge. find something that turns on when you turn your headlights on, like a bulb that lights up a button on your dash. pretty simple stuff. dont twist and tape, solder and heat shrink connections to prevent further problems. goodluck.
Old 09-28-2004, 12:37 PM
liv2wrshp's Avatar
What have you tried so far?
liv2wrshp is offline
Old 09-29-2004, 10:27 AM
92_EGhatch's Avatar
Default Re: HOw to install Gauges???? (EX_AutoXer)
yeah... um the water temp is the electric one and the oil pressure is the mechanical. any idea?
rhd_ej coupe
06-01-2006 04:13 PM
OldSkoolCiv
Audio / Security / Video
10-03-2004 12:40 PM
ukkb920
03-14-2004 12:44 PM
atwaterkid1320
07-29-2003 04:34 AM
knighteg
09-20-2002 08:50 PM
Quick Reply: HOw to install Gauges????
  • Ask a Question
Question Title:
Description:
