strip motor mount
Is it the bolt from the top or the studs that come up?
If its the stud or bolt you can just screw it out and replace it.
if its the actual mount bracket it depends how bad it is, you might be able to just rethread it but it would probably be better if you could just get a scrapyard mount bracket and stick it on there or drill it through and put a longer bolt with a but on the bottom..
