B-series question need help
Old Apr 12, 2008 | 12:40 PM
ILoveMyHonda.'s Avatar
Default B-series question need help
I have a GSR block that I'm building and I'm trying to decide whether to go with a GSR crank and rods or LS crank and rods. What are the pros and cons or each? and what would i have to do to make the LS crank/rods fit or will they fit just like the GSR would?
Old Apr 12, 2008 | 08:02 PM
NJIN BUILDR's Avatar
Default Re: B-series question need help (ILoveMyHonda.)
If your using stock parts the gsr rods are better than the ls,but will only work with the gsr crank.The ls crank and rod will make slightly more displacement and will bolt right in (with slight bending of the piston oilers).
Old Apr 12, 2008 | 09:34 PM
Default Re: B-series question need help (NJIN BUILDR)
I wouldn't be using stock parts. I'm gunna use eagle rods either way. The motor is gunna be boosted. The block is gunna be bored to 84mm. So that would make it a 2.0L if I used the LS crank/rods right? Am I gunna see a noticeable difference in torque with the LS parts or should I just go with the GSR stuff? What would the difference be performance wise between using an LS crank/rods vs. GSR crank/rods?
Old Apr 13, 2008 | 04:45 AM
In the real world and in a boosted engine there is no difference. If I had both I would use the LS.
Old Apr 13, 2008 | 06:13 AM
blkb18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILoveMyHonda. &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't be using stock parts. I'm gunna use eagle rods either way. The motor is gunna be boosted. The block is gunna be bored to 84mm. So that would make it a 2.0L if I used the LS crank/rods right? Am I gunna see a noticeable difference in torque with the LS parts or should I just go with the GSR stuff? What would the difference be performance wise between using an LS crank/rods vs. GSR crank/rods?</TD></TR></TABLE>Punching gsr sleves out to 84 mm will leave the cylinders walls very thin, especially for boost. I hope you are going with aftermarket sleves, or running really low boost with a really good tune.
Old Apr 13, 2008 | 08:22 AM
Default Re: B-series question need help (blkb18)
yes I'm gunna use Darton 84mm M.I.D. sleeves. I was just wondering about the torque difference because of the slightly longer stroke with the LS crank I figured it would make more torque than with a GSR crank.
boostedbimer
Oct 8, 2012 10:42 AM
turbohatch eg6
Jul 23, 2009 06:04 PM
bigbadboy
Aug 28, 2006 06:20 PM
jdmsijdm
Dec 19, 2004 10:53 AM
B18C-EJ1
Jan 19, 2002 11:45 PM
