fuel pressure problem
Old Apr 12, 2008 | 10:02 AM
h2b_sedan's Avatar
Default fuel pressure problem
hey everyone, i've been having ongoing fuel problems with my car. first i had rust in the gas tank so i burned up a couple 255's. so i swapped out tanks and a brand new 255. then it started leaning out AGAIN... so i try fuel filter, nope... tried a adjustable fpr, the only way i can get it to not lean out in boost is to turn the pressure up to like 60 psi. but it doesnt idle right. any suggestions???
Old Apr 13, 2008 | 07:08 AM
h2b_sedan's Avatar
Default Re: fuel pressure problem (h2b_sedan)
bump
Old Apr 14, 2008 | 01:43 PM
h2b_sedan's Avatar
someone's had to have had this problem!!! help!!
Old Apr 17, 2008 | 08:06 AM
h2b_sedan's Avatar
please help!!!!
Old Apr 22, 2008 | 08:01 AM
h2b_sedan's Avatar
ttt
Old Apr 22, 2008 | 04:56 PM
shaunk18's Avatar
damn boy... no one must not like you lol
Old Apr 23, 2008 | 02:07 AM
h2b_sedan's Avatar
Default Re: fuel pressure problem (shaunk18)
i guess not
Old Apr 23, 2008 | 06:26 AM
RACEPAK's Avatar
clogged fuel injectors.
pm me if you need a set.
Old Apr 23, 2008 | 06:30 AM
SuzukaBlueAP2's Avatar
Default Re: fuel pressure problem (RACEPAK)
I don't know anything else about your car or setup other than you are having fuel issues.
Turbo?
SC?
Setup?
Tuning?
Old Apr 23, 2008 | 07:16 AM
da_dude's Avatar
You need to retune it. My car with my mini turbo did the same thing. It was suppose to get dyno tune but my tuner computor was froze so we couldn't do anything. After 2 hours of waiting we just decide to throw in on the dyno anyway and see where it's at from my previous tune. After a lean pull we adjust my AEM fpr up. Made number in my sig with fpr up to 60 psi at vacuum. It'll idle like **** but drives fine. If I turn the fpr back to 40 psi it idle like stock.
Old Apr 23, 2008 | 10:06 AM
h2b_sedan's Avatar
Default Re: (da_dude)
could you please elaborate on the clogged injector problem??? anyone ever have this??? cuz that was one of my guesses.
Old Apr 23, 2008 | 11:41 AM
da_dude's Avatar
^Pull the injector clips one at a time. If the engine start to die or changes than that injector is working. If you unplug a injector clip and the engine still sound the same or running that that injector bad or clog.
Old Apr 23, 2008 | 12:31 PM
h2b_sedan's Avatar
sweet thanks da dude
Old Apr 23, 2008 | 03:01 PM
shaunk18's Avatar
Default Re: (h2b_sedan)
bump
Old Apr 24, 2008 | 02:02 AM
h2b_sedan's Avatar
Default Re: (shaunk18)
thank you sir
Old Apr 24, 2008 | 10:40 PM
shaunk18's Avatar
is it fixed sir!!!!!
i like beer
Old Apr 25, 2008 | 07:29 AM
h2b_sedan's Avatar
not really sir but i'm working on it!!! might try new injectors
Old Apr 25, 2008 | 09:51 AM
shaunk18's Avatar
gett'r done
Old Apr 27, 2008 | 10:57 AM
c.ridgell's Avatar
bump
Old Apr 28, 2008 | 07:42 AM
h2b_sedan's Avatar
Default Re: (c.ridgell)
so i pulled the injectors and sprayed them all with carb cleaner. seemed to srtaighten it up quite a bit. so imma order some new injectors i guess
Old Apr 29, 2008 | 10:48 AM
RACEPAK's Avatar
told ya
Old Apr 30, 2008 | 07:42 AM
h2b_sedan's Avatar
Default Re: (RACEPAK)
great call RACEPAK!!! kudos to you my friend
w00ted
May 8, 2009 07:56 AM
Maxime
Jul 10, 2005 05:46 AM
hcarcrx
Jul 3, 2004 05:54 PM
I Like Boost
Nov 24, 2003 01:28 PM
rbf351
Nov 27, 2002 07:28 AM
