i searched....y7 bottom z6 head...mini me...94 ex civic coupe
i own a 94 ex and the bottom started knocking(240kmi)....i recently bought a y7 with bent valves. i took off the head and cylinder walls look good as well as crank spins freely.....
watre pump im pretty sure has to be y7 but head gasket and timing belt im unsure of.....
im guessing the 3 layer honda HG from z6 or y8 and confused on which belt?
also is there any oil plugs or dowel pins or any thing like that that i have to remove from the y7 block?
thanx for the info...
You always use the timing belt that goes with the head, as far as the headgasket go with the Y7/Y8 since it's less expensive. Use the Z6 headbolts Go herre https://honda-tech.com/forums/honda-...oodbye-554053/
dohc4life
Aug 14, 2010 08:50 AM
mario_pic
Nov 21, 2008 08:12 PM
DA91TEGGY
Apr 19, 2005 03:55 PM
