FPR for bolt-ons ??
Old Jul 11, 2002 | 07:33 AM
shivers's Avatar
Default FPR for bolt-ons ??
Here's the rundown:
2000 Si
AEM CAI
JDM 4-1
A. Teo 2.5" cat
Greddy EVO
VAFC
I'm going back to the dyno in two weeks to retune thanks to the recent header and cat addition. I plan to run this set-up until I get cams, valvetrain, etc. sometime next year.
My question is this ... should I get a fuel pressure regulator before I go back to the dyno? I've read where people have recommended increasing fuel pressure with a FPR and using the VAFC for fine tuning. The first time I tuned (i/e/vafc) we removed fuel in the upper range and added a bit at the cam crossover. The a/f ratio was right on at 13.2-13.4. So, any thoughts or suggestions?? Any help is appreciated.
Old Jul 11, 2002 | 08:52 AM
ALLMOTOR18's Avatar
Default Re: FPR for bolt-ons ?? (ajm_00Si)
if you want to tune more on the dyno get cam gears...
it will help more than the FPR...
Old Jul 11, 2002 | 10:32 AM
shivers's Avatar
Default Re: FPR for bolt-ons ?? (GSRTypeR)
Cams, gears, valvetrain, etc. is on the list for next year. The plan is to get the $$ together and do everything at once. I'm just trying to figure out some preliminary support mods ahead of time. Dyno time is practically free for me, so it's not a big factor.
Old Jul 11, 2002 | 10:50 AM
I Like Boost's Avatar
with your bolt-ons you should be fine with stock fuel pressure, when you start doing major work (cams, ect.) you should get a fpr, but for now you don't need it. but you should diffentaly get cam gears befor you next dyno sesson to get the most out of tuneing your setup. only 200$ for a pair of skunk2 gears. you should just get them out of the way now because in the future your gnna need them anyways.....
Old Jul 12, 2002 | 02:31 AM
kinesistech's Avatar
Leave the pressure alone. You already have it setup well. Sometime goods enemy is better. It you add one you're ginna have to redo a lot instead of a little. Just get it and add it to the pile for next years parts.
Old Jul 12, 2002 | 07:32 AM
shivers's Avatar
Default Re: FPR for bolt-ons ?? (kinesistech)
Thanks for the info/suggestions, guys. I'll just add the FPR to the list of parts for next spring.
Im-Gay
Aug 22, 2004 04:31 PM
[ iLL ] iNt3GrA
Dec 17, 2003 08:25 PM
The HamsterBall
Feb 1, 2003 12:47 AM
EleanoR
Feb 28, 2002 07:44 PM
Malice
Feb 11, 2002 10:36 PM
