Oil leaking when vtec engages????
Old Jul 11, 2002 | 12:05 PM
dubnine's Avatar
Default Oil leaking when vtec engages????
Whenever i smash on my car it oil drops on the header by the o2 sensor and smokes up real bad... I don't see any oil around the vtec sylenoid, and no oil around the oil filter, there is some seepage coming from the oil pan where its meets the block, but it only leaks real bad when i drive hard... My motor is a 2001 b18c5 with a GSR head... Another theory i have is maybe its coming out of the tranny, do lsd trannys use different axle seals???
Also, i had to set my idle at 1200 so it will idle normal with the ac on... Why isn't the motor compensating when my ac is on????
Thanx in Advance
Mike
Old Jul 11, 2002 | 12:07 PM
96_GSR's Avatar
Default Re: Oil leaking when vtec engages???? (dubnine)
If you bought it new or used, it still should be under warranty..Take it back asap..that's ridiculous.
Old Jul 11, 2002 | 12:27 PM
dubnine's Avatar
Default Re: Oil leaking when vtec engages???? (96_GSR)
i bought a whole wrecked integra, and since i put the motor in myself in my car, warranty is void...
Another thing could the small b16 header cause the oil pan to leak? Cause it is up against the oil pan....
Old Jul 11, 2002 | 12:29 PM
Kamin's Avatar
take your oilpan off
replace the gasket
put some liquid gasket on it
and reinstall
it sounds like the oil is leaking onto your header.
Old Jul 11, 2002 | 12:49 PM
CivicEK.PDX's Avatar
yes the b16 header is probaly moving the oil pan and causeing i to drip.
Old Jul 12, 2002 | 02:19 AM
kinesistech's Avatar
As for your idle problem. Check to make sure you didnt confuse the power steering pressure switch plug with the IACV plug. It wont throw a code or adjust your idle. My friend was at the dealer 5 times with that problem and I found it in 1/2 and hour. Can you say refund.
Old Jul 12, 2002 | 07:57 AM
dubnine's Avatar
Default Re: Oil leaking when vtec engages???? (kinesistech)
Never knew that those plugs were the same... I need to check that out, cause i'm actually driving with my IACV disconnected, cause with it plugged in it idles at 2000....
Thanx
MumBleZ_94gsR
May 30, 2009 03:26 PM
tw1nny03
Mar 3, 2008 05:29 AM
TahitianEG
Jul 2, 2007 03:17 PM
