scs service connector
Old Apr 11, 2008 | 01:41 PM
Frickr's Avatar
Default scs service connector
when you jump the service connector, you will be able to pull up the codes that you are throwing from a check engine light right? and also, will the codes from a B16A2 be the same codes used for a D16Y8? i found a list of codes for a b16, but i want to help my friend out with his car. he the dealership replace his head, and when we got it back noticed his distributor was loose, so i was gonna check the timing for him, and also what light on the dash do you look at to count the flashes? i couldnt find to much information in the arcives about this subject, mostly how to jump it.
Old Apr 11, 2008 | 01:44 PM
philosofy1's Avatar
Default Re: scs service connector (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">when you jump the service connector, you will be able to pull up the codes that you are throwing from a check engine light right? and also, will the codes from a B16A2 be the same codes used for a D16Y8? i found a list of codes for a b16, but i want to help my friend out with his car. he the dealership replace his head, and when we got it back noticed his distributor was loose, so i was gonna check the timing for him, and also what light on the dash do you look at to count the flashes? i couldnt find to much information in the arcives about this subject, mostly how to jump it.</TD></TR></TABLE>
it doesn't make a difference what motor it is, the codes are the same!
Old Apr 11, 2008 | 01:47 PM
Frickr's Avatar
Default Re: scs service connector (philosofy1)
thats what i figured but i wasnt sure. now to check it you just jump the wire with a spade terminal, then watch what light on the dash?
Old Apr 11, 2008 | 01:50 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">thats what i figured but i wasnt sure. now to check it you just jump the wire with a spade terminal, then watch what light on the dash?</TD></TR></TABLE>
yes, i usually use a paperclip. just jump it (with the car not running). one quick flash are 1's and long flashes are 10's.
Old Apr 11, 2008 | 01:53 PM
Frickr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
yes, i usually use a paperclip. just jump it (with the car not running). one quick flash are 1's and long flashes are 10's.</TD></TR></TABLE>
alright thanks alot, and the check engine light flashes?? this is all new stuff for me, i need to pick up a helms manual..
Old Apr 11, 2008 | 02:36 PM
Frickr's Avatar
alright a little more searching, and i figured it all out, thanks HT!
Old Apr 11, 2008 | 02:40 PM
philosofy1's Avatar
Old Apr 11, 2008 | 02:50 PM
Targa250R's Avatar
be professional
With an OBD-II car, you're better off plugging it into an OBD-II scanner. You get more specific information on the problem that way. Jumping the SCS connector to read the CEL will just give you a general code.
Some auto parts stores (like AutoZone) will do an OBD-II scan for free. Just don't go with any of their recommendations on a fix, because most don't know what they're talking about and are just looking to sell you a bunch of useless parts . . .
Old Apr 11, 2008 | 02:55 PM
philosofy1's Avatar
Default Re: scs service connector (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Just don't go with any of their recommendations on a fix, because most don't know what they're talking about and are just looking to sell you a bunch of useless parts . . .</TD></TR></TABLE>
Old Apr 11, 2008 | 03:19 PM
Frickr's Avatar
well the general code will be better then nothing. bot of us are broke, so we cant afford to get a scanner. and no place around here will do it for free, let alone have the scanners themselves.
Old Apr 11, 2008 | 10:46 PM
NOFX's Avatar
H-T White Ops
Autozone was selling $40 scanners. Some might still have them in stock. The part number is CP9125. It's likely there is one in a store near you.
Old Apr 11, 2008 | 11:25 PM
Frickr's Avatar
Default Re: (NOFX)
i checked at napa, our only part store, and 2 they have there are both over 100. ill be purchasing a nice set of tools here in the next year, and thats gonna be one of the things i get.
Old Apr 11, 2008 | 11:26 PM
NOFX's Avatar
H-T White Ops
The Actron one I mentioned is $60 on their site IIRC.
Old Apr 11, 2008 | 11:32 PM
Frickr's Avatar
Default Re: (NOFX)
this is my friends car, but i was mostly curious about all of this stuff after reading up on how to time the distributor, and happened to come across this in my searching. never hurts to learn somethin new haha but i thank you guys for all the input.
Old Apr 12, 2008 | 10:56 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">well the general code will be better then nothing. bot of us are broke, so we cant afford to get a scanner. and no place around here will do it for free, let alone have the scanners themselves. </TD></TR></TABLE>
buy a scanner, what such nonsense. they do it for free. if you have a car 96 - up, you just go over and tell them that you have a CEL and they scan it for free and tell you the code of the problem.
Old Apr 12, 2008 | 11:51 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">buy a scanner, what such nonsense. they do it for free. if you have a car 96 - up, you just go over and tell them that you have a CEL and they scan it for free and tell you the code of the problem.</TD></TR></TABLE>
North Dakota is the land of nothing. The population density is like 9.30/mi^2. There probably isn't a place within 50 miles that will do it.
Old Apr 12, 2008 | 12:37 PM
philosofy1's Avatar
North Dakota is the land of nothing. The population density is like 9.30/mi^2. There probably isn't a place within 50 miles that will do it.</TD></TR></TABLE>
WOW, that sucks.
Old Apr 12, 2008 | 03:44 PM
Frickr's Avatar
probably even further then that.. haha the closest walmart is 75 miles from me. 300 for anything else... got a napa though!
Old Apr 12, 2008 | 08:58 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">North Dakota is the land of nothing. The population density is like 9.30/mi^2. There probably isn't a place within 50 miles that will do it.</TD></TR></TABLE>
I did a search for Autozones near Frickr and the closest I got was I think 284 miles away.
Crippledduck51
Jan 19, 2007 01:32 PM
egturbolsvtec
Mar 15, 2006 03:20 PM
Prisky
May 4, 2005 10:22 PM
Clydsdal
Sep 21, 2003 08:15 AM
