36mm 5 lug question
i got the jdm 5 lug 36mm suspension and needed to change the brakes and rotors. just wanted to know if i can use the usdm rotors and brake pads on this, if not what kind and where can i get some? thanks
yes you can use the usdm itr rotors and pads, the only thing that is different is the hub (where the axle goes through it is 36mm vs. the 32mm of the ctr/usdm)and because of that the axle is diffrent too. Everything is basically the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjesus »</TD></TR><TR><TD CLASS="quote">99 crv axles is what i just used on same set up 2wd manual ones</TD></TR></TABLE>
WITH ABS
WITH ABS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjesus »</TD></TR><TR><TD CLASS="quote">cant use ABS on 36mm to big so no ABS</TD></TR></TABLE>
what does the size have to do with abs?
