Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Squeaking Noise?!
Old Apr 11, 2008 | 12:38 PM
knaira112387's Avatar
Default Squeaking Noise?!
So whenever I release the clutch (with the car on) and get ready to go i hear a belt squeaking noise?! i can only hear the squeaking when the motor starts to struggle to go forward.. but when i start going i don thear it any more? meaning i only hear it when i start to release the clutch when it catches it makes that squeaking noise.
Old Apr 13, 2008 | 11:12 AM
irnhyd889's Avatar
Default Re: Squeaking Noise?! (knaira112387)
I'm having the same problem, and I can't seem to figure it out. I tried explaining it to one of my friends but mine sounds almost like a slight metal to metal grinding squeak, like break pads on the metal touching the rotor. but hey if anyone has any answers, i'd like to know too.
Old Apr 13, 2008 | 09:56 PM
anyone?????????
Old Apr 14, 2008 | 03:56 AM
siboii08's Avatar
Default Re: (knaira112387)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knaira112387 &raquo;</TD></TR><TR><TD CLASS="quote">So whenever I release the clutch (with the car on) and get ready to go i hear a belt squeaking noise?! i can only hear the squeaking when the motor starts to struggle to go forward.. but when i start going i don thear it any more? meaning i only hear it when i start to release the clutch when it catches it makes that squeaking noise.</TD></TR></TABLE>
I usually have the same problem, Then the motor is not warmed up... but, I can't tell you exactly what it is.. is the noise constant... Through out the whole day?
Old Apr 14, 2008 | 08:49 AM
like i said it only happens when im starting to go when the motor isnt given to much throttle while releasing the clutch.. therefore creating the motor to struggle a lil bit more.. immean i cant hear it in the cabin or anything but when im in like a drive through like mcdonalds for example i can hear it because im next to a wall and the sound doesnt travel too far..
Old Apr 18, 2008 | 11:22 PM
anyone got an idea? all it really sounds like is a belt squeak when i release the clutch to let it go on its own..
Old Apr 20, 2008 | 08:12 AM
tsdunay's Avatar
I had this problem, and after hours of tearing my car apart, I found where the actual noise was coming from. The bushing the clutch pedal pivots on was where the squeaking was coming from. I crawled on the floor of the car and added some lube to it, pushed it in and out with my hand, and added a little more lube. Then no more squeaking noise.
Old Apr 20, 2008 | 09:02 AM
jt61583's Avatar
same noise here... its under the car near the trans. i think it has some
thing to do with the mounts because its only once you put a little stress on the clutch
Old Apr 20, 2008 | 03:28 PM
tsdunay's Avatar
Default Re: (jt61583)
yeah it sounds like it it is out side the car, but really it is under the dash, just crawl on the floor of your car, and look to see where the clutch pivots. There is a rubber bushing there. That is the part making the sound. Mine always squeaked when the clutch was released about half way.
Old Apr 20, 2008 | 08:05 PM
its a constant belt squeaking noise that im talking about though?
Old Apr 21, 2008 | 01:34 PM
tsdunay's Avatar
only when pressing the clutch in?
Old Apr 21, 2008 | 03:12 PM
irnhyd889's Avatar
Default Re: Squeaking Noise?! (tsdunay)
my sistuation is when the clutch is nearly engaged with the flywheel and SLIGHTLY it starts to make a metal grinding noise like brakes going metal2metal.
Old Apr 22, 2008 | 09:08 PM
what he said
Old Apr 22, 2008 | 09:38 PM
07nhbpsi's Avatar
Mine used to do that all the time but magically one day it stopped. I've never had any problems with my clutch and i'm at 13,xxx miles.
Old Apr 23, 2008 | 09:20 PM
MisterNiceGuy's Avatar
Default Re: (07nhbpsi)
Take it to Honda they'll fix it.
https://honda-tech.com/zerothread?id=2074137
Old Apr 27, 2008 | 09:35 PM
took it to honda. both said that its not too noticable so they wont fix it.. thats so eff'd up! omg.. what did you guys lube up? im going to do it myself..
Old Apr 28, 2008 | 06:49 AM
TUR3Ovtec's Avatar
DONT WORRY GUYS got it covered LOL... i noticed it one day when I was moving my car into the garage with the door open... i tried my friends car and his did the same so i didnt go to the appt. i had already scheduled. BUT i just made a call now to bring the car in on Friday so i will def. let you guys know what it is. BTW I will be using this thread for refrence.
Old Apr 28, 2008 | 02:26 PM
thanks.. i even showed the service writer the thread.. and it didnt even help.. they wouldnt even take a look at my car.. [freak]in ********.
Old Apr 28, 2008 | 02:27 PM
excuse my language sorry im surprised a**holes isnt expletived out.. haha
Old May 2, 2008 | 12:25 PM
so what part did you guys lube up?
Old May 2, 2008 | 08:11 PM
PolishSasquatch's Avatar
im hav ing a hard time believing thats its just the pivot at the pedal, especially since OP says he's getting some xtruggling with the motor? cluth fluid perhaps? coudl explain the metal on metal noise. I hate dealers, I have a harmonic/osciallating sound from my matrix crusing 70-110k/h told the dealerships sais they cant do anythgn about it. [freak] them
Old May 4, 2008 | 09:44 AM
Default Re: (PolishSasquatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolishSasquatch &raquo;</TD></TR><TR><TD CLASS="quote">im hav ing a hard time believing thats its just the pivot at the pedal, especially since OP says he's getting some xtruggling with the motor? cluth fluid perhaps? coudl explain the metal on metal noise. I hate dealers, I have a harmonic/osciallating sound from my matrix crusing 70-110k/h told the dealerships sais they cant do anythgn about it. [freak] them</TD></TR></TABLE>
finally someone knows what im talking about.. its coming from outside of the car.. i checked everything clutch fluid is still sitting high. i hateeeeeeeeeeee this noise its annoying.
Old May 5, 2008 | 07:12 PM
anyone??????????!?!?!
Old May 6, 2008 | 06:38 AM
SI_you_later's Avatar
I've gone in twice for that reason and they've replaced the gasket both times.
Old May 6, 2008 | 07:10 AM
TUR3Ovtec's Avatar
Default Re: (SI_you_later)
OK so i went on friday and found out what the noise is coming from... its from the exhaust system moving around from all the places it could of been. The little rubber peice that holds the hanger on is moving around and i think they replaced a gasket also where the cat is connected and sprayed some high temp bullshit... squeaking stopped for now. im sure it'll come back again.
If your going to go try just move the peice where the header meet cat and it will make the sound.
