LS
WILL A MOD PLEASE EDIT MY TITLE
Going to swap my 96 EK soon have ls/vtec in it now and can either fully build/sleeve boost it or ditch that and go k series prolly with a mild low compression low boost build...
looking at a
84mm LS/Vtec Sleeved block, b16a PNP head, cams, boosted
vs
k24 low compression block w/ k20 head, boosted, with all addons
looking at a
vs
i dont really have a set budget right now, i figured a fully built boosted b series wont be that much more than a mild build boosted K,
if i went B id be replacing Everything anyways (axles, shift linkage, harness, ecu, etc)
and Hondata ecus and much cheaper than Kpro
+ i wont have to sleeve it
...Not to mention time spent on it. There's also the way k-cars are theft magnets moreso than normal turbo Hondas.
The only reason I'd go with a K24 is if it was going to be a street machine in which I was a fatass and had a few hundred pounds of stereo system. I've neither, and most people don't as well. FYI you can push the fully built B to mild built K power levels w/o needing sleeves. If you're thinking mild built K = 600whp, thats a different story.
You just need to ask yourself what you need this for, and write down the pros/cons of each. IMO the only real benifit of K's is the extra displacement. T-chain and 6spd is a plus for the street, otherwise there's nothing that seriously stands out.
car is going to be a DD street car, i will prolly just build my xtra LS block i have in the garage seems like it will be cheaper and easier...
should i go 84mm and sleeve it or 81.5mm save the money...
looking for about 450-500 on race gas...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jksmith »</TD></TR><TR><TD CLASS="quote">WILL A MOD PLEASE LOCK MY THREAD
fixed
fixed
