LS
Old Apr 11, 2008 | 11:52 AM
jksmith's Avatar
Default LS/Vtec vs K Series
WILL A MOD PLEASE EDIT MY TITLE
Going to swap my 96 EK soon have ls/vtec in it now and can either fully build/sleeve boost it or ditch that and go k series prolly with a mild low compression low boost build...
looking at a
84mm LS/Vtec Sleeved block, b16a PNP head, cams, boosted
vs
k24 low compression block w/ k20 head, boosted, with all addons
Old Apr 11, 2008 | 12:51 PM
totsie7944's Avatar
Default Re: LS/Vtec vs K Series (jksmith)
How much can you afford to spend? B-series and K-series are pretty much even when you boost them....
Old Apr 11, 2008 | 03:27 PM
jksmith's Avatar
i dont really have a set budget right now, i figured a fully built boosted b series wont be that much more than a mild build boosted K,
if i went B id be replacing Everything anyways (axles, shift linkage, harness, ecu, etc)
and Hondata ecus and much cheaper than Kpro
+ i wont have to sleeve it
Old Apr 11, 2008 | 10:17 PM
stewie8apie's Avatar
Default Re: (jksmith)
just build a b and throw it in there....you will spend too much money on the k swap.
Old Apr 11, 2008 | 10:34 PM
HiProfile's Avatar
Default Re: (stewie8apie)
...Not to mention time spent on it. There's also the way k-cars are theft magnets moreso than normal turbo Hondas.
The only reason I'd go with a K24 is if it was going to be a street machine in which I was a fatass and had a few hundred pounds of stereo system. I've neither, and most people don't as well. FYI you can push the fully built B to mild built K power levels w/o needing sleeves. If you're thinking mild built K = 600whp, thats a different story.
You just need to ask yourself what you need this for, and write down the pros/cons of each. IMO the only real benifit of K's is the extra displacement. T-chain and 6spd is a plus for the street, otherwise there's nothing that seriously stands out.
Old Apr 12, 2008 | 04:46 PM
jksmith's Avatar
car is going to be a DD street car, i will prolly just build my xtra LS block i have in the garage seems like it will be cheaper and easier...
should i go 84mm and sleeve it or 81.5mm save the money...
looking for about 450-500 on race gas...
Old Apr 12, 2008 | 08:07 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jksmith &raquo;</TD></TR><TR><TD CLASS="quote">WILL A MOD PLEASE LOCK MY THREAD
fixed
Old Apr 25, 2008 | 02:48 PM
jksmith's Avatar
bump...
Joelz-Santana
Mar 11, 2009 04:53 PM
slow_redcivic
Oct 7, 2005 01:04 PM
Gizmo1313
Jun 28, 2005 10:10 PM
DriveSlowHomie
Jan 26, 2005 08:59 AM
jbell
Feb 6, 2004 01:43 PM
