Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Are these rear bars mounted properly? I'm thinking no...
Old Apr 11, 2008 | 04:26 AM
vbspec's Avatar
Default Are these rear bars mounted properly? I'm thinking no...
Can you mount your rear bars like this???
The way I read the rules the rear bars must be mounted to plates. The plates can be boxed and a chassis stiffeneing bar can be installed inbetween the boxed mount points.
Old Apr 11, 2008 | 08:59 AM
Erik95LS's Avatar
Default Re: Are these rear bars mounted properly? I'm thinking no... (vbspec)
you can yes.......should you? Not in my opinon. Some rules packages allow mounting like that while many others do not. Just depends on what series it's for or personal use.
I sure wouldn't do that though.
Old Apr 11, 2008 | 09:11 AM
Lo-Buck EF's Avatar
Default Re: Are these rear bars mounted properly? I'm thinking no... (Erik95LS)
for nasa (and probably for scca) no. the down tubes are to contact the chassis at a box or plate. not a tube.
Old Apr 11, 2008 | 09:44 AM
TunerN00b's Avatar
Default Re: Are these rear bars mounted properly? I'm thinking no... (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">for nasa (and probably for scca) no. the down tubes are to contact the chassis at a box or plate. not a tube.</TD></TR></TABLE>
I'm not a drag guy, but wouldn't that be a legal NHRA cage?
Old Apr 12, 2008 | 12:43 AM
jeffy's Avatar
Default Re: Are these rear bars mounted properly? I'm thinking no... (TunerN00b)
isnt the horizantal harness bar supposed to be 1 solid piece as well?
Old Apr 12, 2008 | 01:44 AM
RS-2's Avatar
sure, but tighten up those weld pols, they seem big and loose.
Old Apr 12, 2008 | 03:42 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Are these rear bars mounted properly? I'm thinking no... (jeffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffy &raquo;</TD></TR><TR><TD CLASS="quote">isnt the horizantal harness bar supposed to be 1 solid piece as well?</TD></TR></TABLE>
Nope (for NASA). Diagonal in the main hoop does have to be one piece though. The "suggested" cage diagram for SCCA cars does have the harness bar as one piece with the diagonal split, but the NASA design is also acceptable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not a drag guy, but wouldn't that be a legal NHRA cage?</TD></TR></TABLE>
Technically yes. But if it was designed for NHRA, it wouldn't have the diagonal.
Old Apr 13, 2008 | 08:18 PM
turboteener's Avatar
Banned
I hate that design. **** poor engineering. Never load a critical tube like that in a bending. It will crush that tube and then rip it off the chassis
There is nothing wrong with those welds. I might run a little more wire speed, but there is nothing wrong with those welds. Tiny welds are for show.
dank24
Honda Fit
Jul 24, 2007 05:26 AM
zerons hell
Jul 31, 2006 06:59 AM
.one lane
Welding / Fabrication
Mar 16, 2006 06:39 AM
BB6-213
Aug 22, 2005 02:09 PM
sshaikh01
Apr 24, 2003 09:43 PM
