too much nox???
Old Jul 11, 2002 | 04:39 AM
Jockobo's Avatar
Default too much nox???
how do i lower the nox levels??? its the only thing that i cant pass and its at 3500. would putting in a stock exhaulst help out??? thanks.
Old Jul 11, 2002 | 04:45 AM
John's Avatar
New User
Default Re: too much nox??? (Jockobo)
Try tuning your A/F mixture to a stoicmetric level first.
Old Jul 11, 2002 | 07:17 AM
brcivic411's Avatar
Default Re: too much nox??? (DunReit)
menthanol (just a little bit)
retard your timing (all the way until idle suffers)
change plugs to a colder set
add a cup of bleach to your gas tank
(I take no responsibility for any damage in doing the above actions... do it at your own risk!!)
Old Jul 11, 2002 | 08:02 AM
TDRacing's Avatar
Default Re: too much nox??? (brcivic411)
that's funny------------>menthanol (just a little bit)
Then at the bottom----->1998 Blown EX Do you want to trust this guy?
Old Jul 11, 2002 | 09:12 AM
brcivic411's Avatar
Default Re: too much nox??? (TDRacing)
most definitely not!
blown ex means turbo ex.. not a 'blown up' ex (at least not yet)
i was just offering suggestions
Old Jul 12, 2002 | 02:36 AM
kinesistech's Avatar
Retarding timing until idle suffers will increase combustion chamber temps even more and thats the cause of NOx. If you have an exhaust leak, then the stock exhaust may help. Try removing carbon from the combustion chamber with an intake system cleaner, or water misted into the intake pipe with a spray bottle.
eL_cArLos
May 10, 2010 08:34 PM
Ohbebe75
Sep 16, 2009 01:20 PM
cleanda6
Sep 12, 2006 11:36 AM
tomegun123
Aug 10, 2005 06:16 AM
ramennoodles
Jun 29, 2004 02:15 PM
