what fuel pressure to run?
Old Jul 11, 2002 | 07:57 PM
kingrobby's Avatar
Default what fuel pressure to run?
i have a 94 integra ls with an cai/h/e with a aem fuel rail, filter, and fuel pressure reg. i was just wondering what would be a good fuel pressure to run. i turned it up from 40psi to 45psi. the aem booklet said anywhere from 40 to 47psi. my friend has a 2000 si with the same upgrades and a 75 shot of nitrous any suggestions for him? he is running 48psi right now. thanks
Old Jul 12, 2002 | 01:57 AM
kinesistech's Avatar
Default Re: what fuel pressure to run? (kingrobby)
I wouldnt make yours any higher and I would leave your friends alone, his nitrous is setup at his current fuel pressure. Stock is 40-47 depending on the engine. I dont see any need for more than 45 for both of you. Remember that fuel pressure is set with the vaccum line disconnected and plugged.
Old Jul 12, 2002 | 03:17 AM
Mista Bone's Avatar
D Tranny Guru
using AEM regulator?
Run stock pressures, you've done nothing to motor to need to jack the pressure up.
envision
Aug 26, 2015 02:00 PM
BuiltCivic99
Jun 13, 2009 01:48 PM
IntegraGSR-Turbo
Feb 27, 2007 07:16 PM
one8toh8
Feb 4, 2005 08:50 AM
