--------> Tokico Illumina Dilema, if you own a set please chime in :D
Old Apr 10, 2008 | 08:55 PM
96Civic_Coupe's Avatar
Default --------> Tokico Illumina Dilema, if you own a set please chime in :D
Ok, so i tried adjusting my rear illuminas on my 5th gen, but the number dial spins and i dont know what setting the rears are set on.
basically i need to know in what direction will the arrow need to point for the stiffest setting (which i believe is 5?)
thanks for the help
Old Apr 11, 2008 | 11:07 AM
f22builder's Avatar
Default Re: --------> Tokico Illumina Dilema, if you own a set please chime in :D (96Civic_Coupe)
I have a set on my lude and I have the little red thing in middle pointed with the arrow to the number. 5 is the "stiffest setting".
Old Apr 11, 2008 | 11:43 AM
ok but what direction in the arrow pointing to?
my number dial spins and i have no way of telling what setting im on.
Old Apr 11, 2008 | 12:56 PM
QUIETP_11's Avatar
Default Re: (96Civic_Coupe)
If the numbers/dial is properly seated, then it does not spin. You may need to find the proper seating and hold it in place while you change settings
Old Apr 11, 2008 | 03:26 PM
NormanBates's Avatar
I had the same problem....so I called Tokico and they sent some new ones - free
Old Apr 12, 2008 | 02:10 PM
anyone else?
i just need to know what direction number 5 is on the rear struts
Old Apr 12, 2008 | 02:42 PM
viper_boy403's Avatar
it's pretty much impossible to find out for sure now lol. You can always just move it one notch, bounce it around, move it another notch, bounce it some more and see which one is stiffer. You'll find out which one is the stiffest because once you go past 5 it goes back to one so it will go from really stiff one round to super soft the next
Old Apr 12, 2008 | 04:13 PM
93sivtec's Avatar
Default Re: (viper_boy403)
I would call tokico and try to hook up some new 1's 4 free.
Old Apr 12, 2008 | 05:56 PM
its not impossible, im sure someone here owns a 5th gen and has their illuminas set on 5, and all i need is a pic of what direction the arrows are pointing to
Old Jun 7, 2008 | 11:34 AM
G2IntegraGS's Avatar
Its going to be different on every car. There is a notch that holds the red cap in place, look for that and seat the dial. If the notch on the red car is broke, just line it up to where the notch used to be before it was broken.
imnotted
Dec 30, 2005 05:44 AM
ILOVEGIRLS
Nov 13, 2003 06:24 PM
tvrsir
Jun 27, 2003 11:05 AM
sslude
Apr 20, 2003 08:33 PM
