Tach wire... I trust you guys!
Old Apr 10, 2008 | 08:05 PM
lilbinky's Avatar
Default Tach wire... I trust you guys!
I have been looking for a little help and cannot seem to find it anywhere so I turn to you guys, because I refuse to post in the Civic forum... I have slightly grown to trust you guys opinion and knowledge.
I have a 1995 Civic that is swapped with a JDM GSR. The setup is a Garret .60 trim tuned on Hondata s200.
The Problem - I got a tach from a guy for a steal... It is the Apexi tach that is really slim.
http://www.apexi-usa.com/produ...Num=1
It works great until I am at full boost and the needle just jumps around like crazy. I can't explain it and neither can anyone I know. Apexi keeps telling me that it is because it is not grounded right, but I do car audio installs for a living and am very familiar with how to ground something. None the less I have actually changed the ground twice and have gotten no results.
Has anyone ever had this problem with a tach and if so how did you fix it?
Sorry this isn't about an RSX or EP3 I just don't want to post in the civic forum with a bunch of idiots... Don't flame just lock if this is not appropriate.
Old Apr 10, 2008 | 11:50 PM
NTCustoms's Avatar
where did you tap it into? you should tap it into the blue wire on the distributor.
Old Apr 11, 2008 | 06:34 AM
lilbinky's Avatar
I was thinking that going closer to the distro may help. I have it closer to the firewall than to to the dizzy.
I will try that and let you know.
My only prpoblem is that the guy I got the tach from had it wired at the ECU. Would this make any difference?
Old Apr 11, 2008 | 05:45 PM
NTCustoms's Avatar
the distributor wire will be more accurate
ramco
Mar 6, 2010 07:30 PM
Mikey3000
Sep 6, 2006 02:32 PM
CimorelliCRX
14
Jul 2, 2005 02:25 PM
Eg6_JDM
Mar 18, 2002 10:33 AM
