T.A.S. Auto - New Accord Parts For Spring
New Spring Products
Check out all the new parts we have added for spring.
AUTO TO MANUAL SHIFTER CONVERSION
Transform the look and feel of your factory automatic shifter with this kit. Make your automatic shift console look like a manual. Your automatic cover plate will be replaced by an OEM shift boot and your traditional automatic push button shift **** will be replaced by a high quality aluminum Razo shift ****. Razo has designed this unit to shift by pushing down on the whole **** instead of pushing the button on the side of your factory unit. Automatic transmissions only.
90-91 AUTO TO MANUAL SHIFTER CONVERSION
Part #711970 Price:$74.95
92-93 AUTO TO MANUAL SHIFTER CONVERSION
Part #711971 Price:$74.95
94-97 AUTO TO MANUAL SHIFTER CONVERSION
Part #711972 Price:$74.95
98-02 AUTO TO MANUAL SHIFTER CONVERSION
Part #711973 Price:$74.95
_________________________________________
BATTERY RELOCATOR KIT
Clean up your crowded engine bay and improve performance with our battery relocator kit. By removing the battery from the engine bay and mounting it in the trunk, you will help balance your car's weight and improve its handling. This NHRA certified kit contains a sealed aluminum battery box, 16' of 2 gauge wire and new hardware.
Part #714810 Price:$155.95
Hasport Swap Components Have Been Added
94-97 HASPORT H-SERIES L/H MOTOR MOUNT
This Hasport mount is designed to make your H22A Prelude engine swap easier. It eliminates the need to modify the Prelude mounts and comes standard with the street (62A) urethane. Using aircraft quality aluminum, Hasport mounts come with a lifetime warranty.
Part #702000 Price:$149.00
94-97 HASPORT K-SERIES ENGINE MOUNTS
Hasport's new engine mount kit is used for swapping the K-Series (with TSX or Accord Transmission) engine into the 94-97 Honda Accord.
- Will Fit with the US Accord K24A4, Element K24A4, TSX K24A2 and the Euro Accord K20A or K24A along with a US 03+ Accord, TSX or Euro Accord manual transmission.
-Designed using sophisticated CAD/CAM engineering software, these mounts provide the utmost in strength and proper fit.
-Using aircraft quality aluminum, Hasport mounts come with a lifetime warranty.
Part #702001 Price:$624.95
94-97 HASPORT K-SERIES AXLES
These brand new Hasport axles are used for the K-series Engine Swap into the 94-97 Accord. Rated to handle up to 200 horsepower at the wheels.
Part #702002 Price:$349.00
Replace the damaged or rusted portion of your cars rear wheel arch with this aftermarket component. Accords are known for having rust in this area. This is a partial patch panel and will require cutting, welding and painting to install.
90-93 SEDAN R/H REAR WHEEL ARCH
Part #405800 Price:$44.95
90-93 SEDAN L/H REAR WHEEL ARCH
Part #405802 Price:$44.95
94-97 SEDAN R/H REAR WHEEL ARCH
Part #405803 Price:$54.95
94-97 SEDAN L/H REAR WHEEL ARCH
Part #405804 Price:$54.95
90-93 4cyl APEXi WS2 CAT-BACK EXHAUST
The World Sport 2 (WS2) concept is A'PEXi's interpretation of how each vehicle's exhaust system should have looked and performed right from the factory. Designed with the daily driver in mind, this exhaust series focuses on drawing out mid-range torque and engine response for optimal drivability on the street. The styling is subtle and elegant, but still retains characteristics of its racing origin. The result is an affordable cat-back exhaust system that makes the daily commute more enjoyable.
Part #710406 Price:$524.95
90-97 POWER SLOT PLUS FRONT BIG BRAKE KIT
The Power Slot Plus system uses a larger diameter, premium brake rotor combined with your original factory brake calipers. Relocation brackets space the factory caliper further away from the hub to accommodate a huge 12.15 oversized brake rotor. This increases brake torque force without affecting pedal effort or travel. The larger rotor is also a more effective heat sink, absorbing the heat generated under heavy braking. This greatly reduces brake fade and provides consistently shorter stopping distances, especially from higher speeds. Bolt-on, no modifications needed.
Fits 90-93 2/4dr cars & all 94-97 2/4dr Accords. Does not fit V6/Wagon models.
Power Slot Plus brake kits require the use of larger diameter wheels.
Part #7129511 Price:$524.95
98-02 4CYL POWER SLOT PLUS FRONT BIG BRAKE KIT
Part #7129512 Price:$524.95
98-02 V6 POWER SLOT PLUS FRONT BIG BRAKE KIT
12.9 oversized brake rotor
Part #7129514 Price:$524.95
98-02 V6 POWER SLOT PLUS REAR BIG BRAKE KIT
12 oversized brake rotor
Part #7129623 Price:$499.95
XS POWER LIGHTWEIGHT BATTERY S680
This compact light weight 12v battery is a great alternative to the large heavy batteries found in your cars. With a start-up output of over 1,000 amps it has enough power to start V8s and weights only 16.62 lbs. Whether you are looking to relocate your battery or just save some weight, this baterry is for you. New terminals included. Not designed for the factory battery box.
Dimensions - 7.28 Long, 3.19 Wide and 6.67 Tall
Part #565680 Price:$149.95
ARP STAINLESS EXHAUST STUDS (SET OF 8)
Replace your rusted and damaged exhaust studs with this stainless set from ARP. If you are installing a new header on your car why use old harware. Include a set of 8 studs. These ARP studs are tested to 170,000 psi tensile strength.
Part #568013 Price:$79.95
ARP's heat-treated 8740 chromemoly wheel studs have a tensile strength of 200,000 psi and are designed to handle the extreme forces of racing. Great addition for any car that will see track time or for anyone looking to give their car the race look. Requires the use of open ended lug nuts such as our #710825. Includes 16 studs.
90-02 ARP EXTENDED WHEEL STUDS (4)
Part #567711 Price:$18.95
90-02 ARP EXTENDED WHEEL STUDS (16)
Part #567713 Price:$59.95
90-02 ARP EXTENDED WHEEL STUDS (5)
Part #567712 Price:$22.95
90-02 ARP EXTENDED WHEEL STUDS (20)
Part #567714 Price:$79.95
We have added the style and performance of Skunk2 to our line-up
90-02 SKUNK2 MAGNETIC DRAIN PLUG SET
This high quality magnetic drain plug set from Skunk2 is designed to remove dangerous metal shavings from your oil and transmission fluids. Help keep your engine running strong and your transmission shift smooth.
Part #710030 Price:$29.95
SKUNK2 BILLET OIL CAP
Replace that plain looking factory oil cap with a Skunk2 billet aluminum oil cap.
Part #710070 Price:$47.95
SKUNK2 SHIFT **** (MANUAL)
This Skunk2 shift **** has a gun-metal finish for that added performance look and feel. Standard transmissions only.
Part #710080 Price:$47.95
90-02 4cyl SKUNK2 CAM SEAL
The Skunk2 cam seal is precision CNC machined from aircraft quality 6061-T6 alluminum billet and is gun metal anodized for a durable finish. The Skunk2 cam seal features three o-rings for a superior fit and seal compared to the factory plastic seal which has no o-rings. Includes a laser-etched Skunk2 logo design to make the Skunk2 cam seal a perfect addition to your engine along with other Skunk2 accessories.
Part #710200 Price:$29.95
90-02 SKUNK2 LUG NUT SET
Skunk2 Racing lug nuts are forged from super strong AL7075 aluminum/magnesium alloy and hard-anodized with knurled ends for better grip. Skunk2 Racing lug nuts are ultra-lightweight and strong and have been proven in all forms of racing. Can be used with extended wheel studs. These lugs have a conical shaped seal for aftermarket wheels. 12 x 1.5 (set consists of 16 lug nuts)
Part #710825 Price:$89.95
90-02 EXTENDED WHEEL STUDS AND LUGS
Combine Skunk2's forged racing lug nuts with ARP's extended wheel studs for the ultimate wheel hardware combination. Skunk2 lugs are made from super strong AL7075 aluminum/magnesium alloy and are hard-anodized. ARP's heat-treated 8740 chromemoly wheel studs have a tensile strength of 200,000 psi and are designed to handle the extreme forces of racing. Great addition for any car that will see track time or for anyone looking to give their car the race look. These lugs have a conical shaped seal for aftermarket wheels. 12 x 1.5. Includes 16 studs and 16 lugs. Buy together and save!
Part #710826 Price:$139.95
90-93 2dr AUTO VENT SHADE WINDOW VISORS
This 2 piece smoked window visor kit is a great functional accessory for your car. While parked, you can leave the windows open an inch or two to keep the interior cool. On rainy days, you can partially open your window without getting soaked, allowing an added bit of ventilation to remove stale or smoky air. Installs with double-sided tape for an easy no drilling installation. Comes with a manufacturer's limited lifetime warranty.
Part #710037 Price:$54.95
90-93 4dr AUTO VENT SHADE WINDOW VISORS
Part #710038 Price:$74.95
New Cam Gears From AC Autotechnic
90-02 4cyl ADJUSTABLE CAM GEAR
This AC Autotechnic cam gear is constructed from t6061 CNC-Machined billet aluminum. Precise machined timing marks allow for adjustability. Their advanced design makes this cam gear light-weight as well as extremely durable. The gear teeth are precision cut and are guaranteed to match the original equipment drive tooth profile.
90-02 4cyl ADJUSTABLE CAM GEAR POLISHED
Part #384001 Price:$74.95
90-02 4cyl ADJUSTABLE CAM GEAR BLUE
Part #384002 Price:$74.95
90-02 4cyl ADJUSTABLE CAM GEAR RED
Part #384003 Price:$74.95
94-97 CHROME TOW HOOKS
These bolt-on chrome tow hooks will give your car the agreesive race look while adding the functionality of an easy to access tow point.
Part #381302 Price:$44.95
<FONT SIZE=""3""><FONT COLOR=""Blue"">TASAuto.com Announces Extended Hours for the Month of May</FONT></FONT>
As the weather continues to improve, we recognize that more of our customers will be taking advantage of the longer daylight hours to work on their cars. With this in mind, we're curious to know if you would like us to extend our hours to help support your springtime projects. During the month of May (2008), our office will be open during the following hours:
* 8:30 am to 8:30 pm, Monday through Friday, Eastern Time
* 10:00 am to 5:00 pm Saturday and Sunday, Eastern Time
Throughout this month long experiment, we will be available to assist you seven days a week. We hope that our extended hours will prove to be especially helpful for our customers who live in time zones far away from the east coast of the U.S. As always, our web site is available to our customers all over the world 24/7. We hope that you will call or email to let us know if you think that these extended hours should be more regular or even permanent. Your opinion is very important to us, so please let us know how we're doing.
Many thanks,
T.A.S. Auto Parts
susboy102
Jul 16, 2014 08:31 AM
realxfresh
May 4, 2009 05:08 PM
TASAuto.com
Jun 18, 2008 04:10 AM
