turbo help is needed here plz
Old Apr 10, 2008 | 07:27 AM
bexisboy5775's Avatar
Default turbo help is needed here plz
ok having some issues here 93 civic coupe y7-y8 head 14b turbo 450 injectors chipped p28 ecu aem fuel rail b16 throttle body hks bov forged pistons rods blah blah blah anyways car has alot of black smoke so rich it wont idle it has no check engine codes it is bugging me just checkin to see what you all would do to fix this problem any ideas???? any suggestions would be nice thanks
Old Apr 10, 2008 | 07:58 AM
JDM Lyfestyle's Avatar
Default Re: turbo help is needed here plz (bexisboy5775)
Is it tuned??
Old Apr 10, 2008 | 08:06 AM
lilo_goki's Avatar
get it tuned, u know how dangerous turbo is if u don't tune it, bang another motor. unless put all the stock parts, like stock injectors and all those other stuff on to see if it's working. what about fuel pump, what are u using.
Old Apr 10, 2008 | 08:59 AM
blk92_d16's Avatar
Yes, the black smoke means you're running pig rich and that's due to you running a stock ecu with whatever Ebay chip that is crap. Even if the chip is a turbo basemap, basemaps aren't meant to actually run on for any length of time. GET A TUNE by a professional.
Old Apr 10, 2008 | 02:25 PM
big-cat's Avatar
black smoke is either running really rich ooooooorrrrrrrrrrrrrrr.......................burni ng a shizit load of oil.....
who built your motor and was it there first time???etc.
Old Apr 10, 2008 | 02:47 PM
grandtheftlunchbox's Avatar
Default Re: (big-cat)
burning oil will cause a bluish colored smoke, not black smoke. he's running rich. period. best thing to do is get ahold of a scan tool and see what kind of duty cycle your injectors are running at. do you have a turbo map sensor?
Old Apr 10, 2008 | 03:14 PM
bigca$ey's Avatar
take it out, and drive hard till its stops.
Old Apr 10, 2008 | 03:36 PM
mynewHaircut's Avatar
Default Re: (bigca$ey)
i had to login just for this^^^^^^ tool. i think you should read around and learn a bit about motors and building them before you start giving your 2cents which will result in a catastrophic failure if someone was dumb enough to take your advice. WTF were you thinking, actually just GTFO!!!! But as everyone says probably just need a good tune.
Old Apr 10, 2008 | 05:03 PM
big-cat's Avatar
Default Re: (grandtheftlunchbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandtheftlunchbox &raquo;</TD></TR><TR><TD CLASS="quote">burning oil will cause a bluish colored smoke, not black smoke. he's running rich. period. best thing to do is get ahold of a scan tool and see what kind of duty cycle your injectors are running at. do you have a turbo map sensor?</TD></TR></TABLE>
brain fart whoops (to many beers)
Old Apr 11, 2008 | 05:24 AM
Haha, i guess too many beers is a good excuse. me like beer.
Old Apr 11, 2008 | 11:29 AM
bigca$ey's Avatar
I was totally just play'n. I see way too many people throw together a setup and not be tuned. AFC's are poop/don't count. Go get it tuned. PLus its hard for us to give advice when we dont know how shotty of a motor you put together. sorry.
90cobraclone
Apr 7, 2012 04:40 AM
Freeltec
Apr 24, 2007 09:52 AM
1baddcivicsi
Oct 29, 2006 08:26 AM
Dan_the_MaN
Oct 24, 2005 10:40 PM
GruvyTune
Sep 19, 2002 05:44 PM
