oil pressure help
Old Apr 10, 2008 | 06:51 AM
96_RHD_EK's Avatar
Default oil pressure help
i have one other problem again i have a 92 civic lx 1.5 the problem im having is the oil light keeps blinking whenever i drive and stop at like a redlight or let it it idle after i been driving i changed the oil pressure sensor and whenever i drive it stays off it just starts blinking whenever i stop i just changed the oil and oil pressure sensor so i dont know what could be the problem any help would be greatly appreciated thanks
Old Apr 10, 2008 | 07:35 AM
96_RHD_EK's Avatar
bump* could someone please help?
Old Apr 10, 2008 | 07:38 AM
Luserkid's Avatar
Default Re: (96_RHD_EK)
Do you have oil? If so then your oil pump could be going out.
Old Apr 10, 2008 | 07:45 AM
96_RHD_EK's Avatar
i have oil i dont have any kind of oil lose its just when ever the car has been drivin for like 20 or 30 minutes and i stop at a light the oil light flickers but whenever i give it gas it turn off i dont know what the problem is
Old Apr 10, 2008 | 07:51 AM
Luserkid's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">your oil pump could be going out. </TD></TR></TABLE>
Old Apr 10, 2008 | 10:07 AM
JDM Lyfestyle's Avatar
+1
I assume the wire is connected because sometimes if the wire is just hanging it will cause the light to flicker as it touches metal and shorts out..I also assume you have the right amount of oil.
Old Apr 10, 2008 | 10:11 AM
ho bag's Avatar
Default Re: (JDM Lyfestyle)
Check the wire to make sure its hooked up.
Also make sure u got oil.
If it still does it replace the sensor, after that its a new oil pump.
Old Apr 10, 2008 | 10:54 AM
96_RHD_EK's Avatar
thanks the plug is connected and i have the right amount of oil guess its the pump how long before it will give out on me? and is it hard to do myself?
Old Apr 10, 2008 | 07:12 PM
96_RHD_EK's Avatar
bump
Old Apr 17, 2008 | 02:06 PM
ho bag's Avatar
Replace the sensor before the pump.
kseriesdreams
22
Jan 30, 2011 04:31 PM
lonewsome
Jan 1, 2009 01:42 PM
BigD306
Sep 26, 2008 06:59 PM
FastAzzDA
Oct 20, 2006 03:07 PM
Supahr_Ed
May 27, 2006 11:51 AM
