Auto lsd in a USDM 5 speed?
Old Apr 10, 2008 | 12:30 AM
Mpower3's Avatar
Default Auto lsd in a USDM 5 speed?
So I got a h22a JDM front clip. It came with an automatic (to my best knowledge) lsd transmission. I was wondering if there was any way I could use the lsd itself in my USDM 1993 vtec h22 transmission. Thanks in advance.
P.S. I did my best with the red button..
Old Apr 10, 2008 | 01:42 AM
98vtec's Avatar
moderator emeritus
Default Re: Auto lsd in a USDM 5 speed? (Mpower3)
automatics had LSD?
Old Apr 10, 2008 | 04:48 AM
mgags7's Avatar
I think he may be right....I can almost remember seeing an h22 come back with an lsd auto once....
After looking over parts diagrams, I think it could work, it is worth a shot at least. Make sure you use the MT ring gear.
Good luck, and take pics of the attempt, I'd love to see
Old Apr 10, 2008 | 09:18 AM
Mpower3's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">I think he may be right....I can almost remember seeing an h22 come back with an lsd auto once....
Good luck, and take pics of the attempt, I'd love to see </TD></TR></TABLE>
These diagrams you speak of, can you post them on here
Old Apr 10, 2008 | 12:42 PM
mgags7's Avatar
slhondaparts.com
I'm simply basing that off the fact that the drawings for the AT diff and the MT diff are different, which implies each is accurate to its own trans. The ring gear had the same number of bolts (10) and the bearings looked to be close to the same on the inner race, which may indicate that the AT diff would be compatible.
None of this is absolutely trustworthy though..
Old Apr 10, 2008 | 12:50 PM
vinuneuro's Avatar
You can't use an M2B4 lsd in a regular H22 trans, and they're both manual trans'. I highly doubt a automatic trans' lsd will fit in a manual trans case.
Old Apr 10, 2008 | 12:53 PM
Mpower3's Avatar
I looked through the website and could find any information on the auto lsd transmission. You said that you saw drawings of the at diff?
Old Apr 10, 2008 | 12:55 PM
Mpower3's Avatar
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">You can't use an M2B4 lsd in a regular H22 trans, and they're both manual trans'. I highly doubt a automatic trans' lsd will fit in a manual trans case.</TD></TR></TABLE>
I'll try to be a little optimistic about it.
Old Apr 10, 2008 | 01:06 PM
vinuneuro's Avatar
Default Re: (Mpower3)
No lsd equipped transmissions were sold in the North American market. That's why those parts diagrams don't make sense. If you already have an lsd out of an automatic, go ahead and tear down your existing trans. I wouldn't even consider buying one though, just because it's not very likely to work.
Old Apr 10, 2008 | 01:33 PM
Mpower3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">No lsd equipped transmissions were sold in the North American market. That's why those parts diagrams don't make sense. If you already have an lsd out of an automatic, go ahead and tear down your existing trans. I wouldn't even consider buying one though, just because it's not very likely to work.</TD></TR></TABLE>
err I know what an lsd looks like..
Old Apr 10, 2008 | 01:37 PM
vinuneuro's Avatar
What does you knowing what a lsd looks like have to do with anything.
Old Apr 10, 2008 | 01:42 PM
Mpower3's Avatar
"No lsd equipped transmissions were sold in the North American market. That's why those parts diagrams don't make sense. "
Modified by Mpower3 at 7:39 PM 4/10/2008
Old Apr 10, 2008 | 04:02 PM
mgags7's Avatar
Vig, we're trying to get a grip on whether the auto transmission's differential is compatible with the 5spd trans.
In JDM land they had lsd autos, which is what I believe he is referring to.
Old Apr 10, 2008 | 04:09 PM
vinuneuro's Avatar
Matt, if the M2B4 diff won't work properly in a say M2F4's case, how can we reasonably expect an auto's diff to work?
CodyCRX
Transmission & Drivetrain
Jul 20, 2012 11:31 AM
r1emperor
Feb 6, 2005 07:23 PM
lilbill3554
Oct 21, 2003 05:05 PM
Tinker219
Mar 1, 2003 09:51 PM
Tinker219
Mar 1, 2003 07:36 AM
