h22 trans
Old Oct 20, 2003 | 02:54 PM
lilbill3554's Avatar
Default ecu
can you use a gsr ecu on h22? if so will it help my car run better?
Modified by lilbill3554 at 2:27 AM 10/22/2003
Old Oct 20, 2003 | 03:15 PM
bad-monkey's Avatar
which parts are you talking about and which transmissions are you talking about?
Old Oct 20, 2003 | 04:13 PM
caLiH22A's Avatar
Default Re: (bad-monkey)
If you are talking about maybe putting the LSD unit from the M2B4 into another non-LSD tranny housing for an H22A, it will not work. From what I know the housing for the LSD unit from the M2B4 is different from the housings of non-LSD H22A trannys.
Old Oct 20, 2003 | 05:13 PM
Default Re: (caLiH22A)
what i was asking can i take the gears 1-5 and use them on my non lsd case
Old Oct 20, 2003 | 11:45 PM
Gerhard_001's Avatar
Default Re: h22 trans (lilbill3554)
Why? Just put the limited slip tranny on. You can do it by the way, just cannot put the LSD in a non-LSD tranny. The LSD casing is a little larger than the non-lsd to accomodate the LSD.
Old Oct 21, 2003 | 04:12 AM
rjr162's Avatar
Default Re: (lilbill3554)
are you looking for the LSD, or as it sounds by your last post, just the closer gearing?
Old Oct 21, 2003 | 05:05 PM
Default Re: (rjr162)
my gears are messed up in the trans i got now. What i want to do is use the gears from the jdm trans with my non lsd diff. Is this possible?
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
manchildteggy
May 1, 2012 10:54 PM
tofast4uh22
Mar 14, 2009 10:08 PM
jim9
Aug 29, 2006 06:19 PM
jaxx4k
Aug 24, 2004 06:34 AM
