tial WG bolt and gasket blown
somehow one of the bolts on my wastegate worked it's way out because the manifold is not stripped. i feel so stupid that i didn't catch it. so anyways i need to find a bolt and gasket for in between the WG and manifold. Does anyone know where i can get these parts.
TIA
cleve
TIA
cleve
You don't need the gasket. It will actually seal better without it, that's part of what that metal ring is for in the Tial. The bolt can be had at any hardware store. Just make sure you get a grade that will handle high heat.
well, i'm in the process of piecing my turbo kit and don't have any of the bolts. i went to every autoparts store around my 'hood, home depot, lowes etc and all they have are those cheap zinc plated steel bolts. you guys know where else i might find some good bolts? was thinking about ss bolts but they only come in the philips head and the allen wrench and are not metric. arrrgh, so frustated, can find a few simple bolts....
theory48,
the bolt i'm talking about are allen head as well. in fact they accept a 1/4" allen wrench. the might also take 6mm but the 6mm i was trying to use was totally messed up. if that helps at all.
yea, i got the size down but everything i found were just zinc plated regular grade steel. i'm looking for some stainless ones. i heard these are rated, grade "g5" or something and are the strongest you can get. i was thinking about just getting the regular ones from home depot but while i was trying em on to see if they fit, and customers/employees started looking at me and telling me that the bolts will get really hot and just snap off like a twig.
I didnt like using those allen bolts...they were too hard to get to and regular bolts i had trouble getting a socket over. I went and bought me some GM metric water pump studs from Autozone and Oreilys and used these for my wastegate and downpipe.
yea, its 10mm 1.25 pitch. 30mm length hope that helps and remember to get the stainless ones not the zinc plated steel ones. still no luck on finding the ss bolts.
-tech are so dope. thanx guys!
