Push button start and i blew somthin up
Old Apr 9, 2008 | 04:39 PM
s5rx7's Avatar
Default Push button start and i blew somthin up
I bought 91 hatch it used have push button start. Their is no ignition in the car all the wires that went to the ignition switch are cut. So i followed these written instruction that the previous owner had made to hook the push button start back up. i used white/black for power. I wired 4 individual wires to that one power wire. i took 4 switches and wired up Acc, Acc2, igniton, Starter. now thiers a white/red wire left and a solid white wire. The solid white wire hit some metal and when it did tht everything shut off i have nothing. no blown fuses anywere. i tried re-wiring everything. I pulled the Ecu out and put it in my other hatch and it worked fine so the Ecu isnt fried. the car is a dx with si interior+harnesses+ECU. yes my other hatch is a real SI so the Ecu's are the exact same. anyone have any ideas on what it could be? Theres a box on the back of the fuse box under the dash could that be fried? Any suggestions?
Old Apr 9, 2008 | 04:53 PM
dr_latino999's Avatar
Default Re: Push button start and i blew somthin up (s5rx7)
Did you check your underhood fusebox?
Old Apr 9, 2008 | 04:54 PM
s5rx7's Avatar
Default Re: Push button start and i blew somthin up (dr_latino999)
yea i checked it good
Old Apr 9, 2008 | 04:57 PM
s5rx7's Avatar
thiers no blown fuses anywere. it seems i have zero power going to all the igniton wires. so i wonder if i have power running to the rest of the fuse box.
Old Apr 9, 2008 | 05:01 PM
kacivic's Avatar
take your battery and have it tested. (i know this isn't exactly the same, but) i accidentally shorted a live wire on my bike and it toasted the battery. it
Old Apr 9, 2008 | 05:07 PM
s5rx7's Avatar
Default Re: Push button start and i blew somthin up (kacivic)
i actually had it running off the battery in my grandmas alero and the alero starts up fine lol. there is no motor or tranny on this car im trying to get it wired so i can make sure all the lights and stuff work before i put a motor in it. Another question. The fuse box under the hood if your standing on the passengers side looking down on the fuse box, all the way on the right side in the lower right hand corner thier is 2 slots with 2 phillips screws. The outer slot is for the + side on the battery and the inner one is for? what wires runn to the inner one have any idea??
Old Apr 9, 2008 | 08:26 PM
s5rx7's Avatar
anyone?
Old Apr 9, 2008 | 08:39 PM
ef dino's Avatar
you blew a fuse man. i install remote starts every day and this happens when your 12 volt ignition wire grounds out. get a probe and tap each end of every fuse under the dash and hood. it wouldnt be a relay. just a fuse. thats what fuses are made for.
Old Apr 9, 2008 | 09:02 PM
91DBSexyTime's Avatar
just for future reference, anytime you wire something, it might be a good idea to unhook the battery so these things dont happen, see now u just have more to deal with.GL bro.
Old Apr 9, 2008 | 09:31 PM
s5rx7's Avatar
Default Re: Push button start and i blew somthin up (ef dino)
Their are ZERO blown fuses.
Old Apr 9, 2008 | 09:40 PM
zrickety's Avatar
have you checked the fuses under the hood with a meter? the screw-in fuses? they may look ok when the element is broke, and the smaller fuses under hood are on different circuits, so they will be fine
Old Apr 10, 2008 | 12:46 PM
s5rx7's Avatar
Default Re: Push button start and i blew somthin up (zrickety)
ill check everything with a meter.
Old Apr 10, 2008 | 01:11 PM
Clipsed's Avatar
just because a fuse does not look popped, does not mean it is still good. You might not have full current running through, and it might be causing issues.
Old Apr 10, 2008 | 01:43 PM
rustbucketrex's Avatar
Default Re: Push button start and i blew somthin up (Clipsed)
Check the 60 amp in the engine bay box. It does not look like a fuse.
Old Apr 10, 2008 | 02:20 PM
crxricer66's Avatar
Default Re: Push button start and i blew somthin up (rustbucketrex)
the spot on the left your asking about is the wire that runs to the starter.
Old Apr 10, 2008 | 04:18 PM
peanut butter's Avatar
Default Re: Push button start and i blew somthin up (crxricer66)
I had this happen from shorting out one of those ignition wires and it was just the fusable link in the fuse box...the 50 or 60 amp one.
Old Apr 11, 2008 | 07:57 AM
s5rx7's Avatar
Default Re: Push button start and i blew somthin up (peanut butter)
Its supposed to rain all day today but as soon as the rain breaks im going to check this stuff. thanks for your help guys ill post back.
jayceng90
12
Jan 9, 2012 03:12 AM
akouznet
May 29, 2009 11:12 PM
Mikal92
Audio / Security / Video
33
Mar 30, 2009 08:02 PM
VegaS10
Oct 7, 2005 02:53 AM
